'85 Ranger Restomod
Modern rubber hose is real bad. I originally had two runs of low pressure rubber hose back there and the pressure side was so weathered that I could bend it and it would just break off. Mind you it was maybe 12-13 years old at most and it sat indoors for 75% of that time. EFI hose is way better - low pressure hose is basically designed to be black & round and that's about all.
Steel brake line was the cheapest and easiest for me so I used it. I had a heck of a time finding two inverted flare to barb fittings locally - online is a different story but that was by far the hardest part. The less rubber you can use, the better.
So, my 5.0l might have a return style system. While doing the cam synchronizer this morning, I looked at the fuel rail. It comes up along each row of injectors and doubles back. I can't see the back of the engune where the regulator and supplt line is. It's tight and crowded back there. So I don't really know for sure yet. I know my 3.0l just has a single tube going around to all the injectors.
something like THIS would be a good way to make new fuel lines...
I do have to say the marine rubber hose with a red stripe and the teflon liner on the inside is good stuff...
That's super cheap for nylon line. At least compared to when I was looking for it at O'Reilly's several years ago. It was something stupid then like $10-ft with minimum purchase of a 100ft roll...
That is a dang good deal.
I don't know about all my connections though. The fuel filter, FPR and TB are all AN fittings.
I'm not really committed to anything in particular yet, this is what I currently have in my spreadsheet for the pressure line.
I'm not exactly sure why I have a strong dislike of AN fittings but I think it's just that you can't go to a parts store or anything and just get them... I have nothing against evil energy though, I've used their stuff before... in some applications AN makes sense, as long as it's robust it's fine I just wouldn't go out of my way to use it... I like quick connects and rubber or nylon more...
The more I work with quick disconnects, at least the automotive ones, the less I like them. Between the not wanting to release due to dirt and other things, and the plastic clips breaking, I am leaning more and more to liking the additional initial trouble of the AN fittings.
That's fair, on my '90 I temporarily shoved hoses over the barbs of the quick connect and put one clamp over the barb and another past it, well that was 15 years ago... on the list but if it ain't broke... :)
Once its together I shouldn't really need to mess with it in theory.
The only real draw to AN is that is what every part of the fuel system comes with. Fuel filter, TB and FPR all come with various who knows what o-ring threads to 06 AN. Just staying with 06 AN seems to really simplify things.
Most Oreilly's and Advance, plus Napa, in my area have a small selection of AN fittings, hoses, etc. No specialty fittings really. Just various -6 and -8 stuff.
My -6AN fuel system has been great for several years now. Never needed any replacement hoses or fittings. You do have to keep an eye on things if you've used the stainless outer jacket type of hose because of it's ability to vibrate and chew through nearly anything it touches. Proper fastening of the line is an absolute must.
I 100% agree with the stainless braided lines needing to be properly secured. We have quite a few of them on aircraft and the damage they can cause is quite impressive. Because of this, some of them come with an additional braided fabric covering of some type to prevent damage from happening, depending on where they are located on the aircraft and what is around them.
This is why I generally prefer to go with AN fittings for fuel as well - it's easy to have some spares around and then everything is using the same thing. For me, I have hydro fittings that are 6AN too
I think all the hydraulic stuff I have is pipe thread :icon_rofl:
Starting issues persist. I have noticed it helps if I pump the pedal like a old Quadrajet. Accelerator pump is pretty inconsistent at startup.
Ran the fuel pump and popped the top off the carb. And the accelerator pump well is basically dry.
Using the old accelerator pump I could move no fuel. But I looking at things I noticed a big chunk of flash across the channel that feeds the accelerator pump.
'85 Ranger Restomod
So I grabbed that and ripped it off with my leatherman
'85 Ranger Restomod
I didn't torque it down but I set the top back on it and turned the fuel pump on again... and we have fuel in the well.
'85 Ranger Restomod
And we have squirtage!
'85 Ranger Restomod
I stuck the spring back in the pump, set the air horn back on and cinched it in place and rechecked and it still worked.
I may very well need to raise the float level. I know a year or two ago I went thru it and dialed everything in and the floats were way off. I wonder maybe if they were high and it all worked until I set things how they were supposed to be and maybe the flash obstructed flow?
I don't know, it is probably another false hope anyway.
Its really crazy to think...15 years ago today I pulled the 2.8 out of this thing.
Its come a long ways... and still has a long ways to go.
