ZF5 in Ranger?
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
I'm in the process of swapping a 302 in my Ranger. I ditched my 2.3t. I'm wondering if anyone has used a ZF5 in a Ranger behind a 302/351. I know people have used the m5od but the ZF5 has its advantages. It has a granny 1st. Its also known to be a stronger trans. I have read that it will not fit without transmission tunnel modifications. I will not ever do a body lift so that is out of the question. I am just curious if anyone has used this transmission and what did they have to do to make it fit?
Thanks!
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Hagan
11
Salem, OR
2.3
Thanks! I think I'll just buy it and run it. If it hits the body I'll cut the tunnel and make it fit!
If not I can use the trans for my 4bt conversion on my f150!
dangerranger83
54
Lafayette, IN
Read carefully as he got a diesel one and has to change some things internally to get it to work, I think it was the input shaft.
Sent from my rooted SPH-D710 using Tapatalk 2
Hagan
11
Salem, OR
2.3
No worries this is the sbf ZF5 trans. It will work on a 351, 302, and 300. Its currently in the guys truck. I am going to drive it today to make sure it shifts then he's going to pull it.
The 460/diesel ZF5 are different.
projectnitemare
8
Osceola Mills, Pa
396W
You will need a body lift unless you want to cut out a large portion of floor and possibly firewall. I had one behind my 396W and had a body lift and the thing barely fit. I can't find any pictures of it, but the width isn't much concern the the height. Even with a 3 inch body lift part of the shift tower will still stick up through the floor. This pic is a ZF vs. M5OD...
The bellhousing/firewall area is tight in a fullsize, I would suggest a body lift.
I liked my ZF at first. I knew my engine made more torque than the 470ft lbs the best ZF5 is rated at. Then I had a clutch explosion. Then I realized a manual doesn't like deep water and mud. So I sold the ZF before I blew it up and went with a C6
Hagan
11
Salem, OR
2.3
Wow, I didn't realize it was that big of a difference!
dangerranger83
54
Lafayette, IN
It's like cramming 10lbs of sausage into a casting made for 5.
Good thing is it has two pto ports that you can use but I don't know of anybody that uses them on their ranger. I figured they would be good for a hydraulic winch.
