Would like to go 65 on the highway
ropinwillie
5
Sublette, ks
Ok so I had a post earlier wondering about fuel pressure and you all answered so that all checked out good. I'm stumped on why I have so little of power for example if I have a head wind of 5mph I might be able to get to 55mph on the highway and with a tail wind I get 65 just barely and I mpg is a constant 12 but I'm just at a loss I've tried different things but to no avail so can anyone give me some ideas just in case it's not clear I have a 89 ranger 2.9l v6
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Different rear end maybe. Gears are your friend. I'm not sure on the specifics, but if everything thing else is in working order, change your rear end to get a different set of gears
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Maybe its broken?
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
My 2.9 will cruise 75 all day.
Does it only do it at higher speeds? You could have a plugged cat.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Swap a 4.0L in it. @PetroleumJunkie412
The 2.9l should be capable of pushing you to/past 65 MPH. Even my 89 2.9l with 35s before I swapped out the 3.73s to 4.56s could do 65. It was struggling to stay there, but it could do it.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Buy a vacuum gauge. There's about a dozen tests you can do with it, one of which is testing for a clogged exhaust.
8,370
Welcome to TRS :)
1989 2.9l has 140HP, makes best power/torque at 2,600rpm, you have an A4LD automatic, 4-speed OD
Stock tire size, 28"?
Or 32" big ones, lol?
It matters, alot
So try shifting down to 1st, then run speed up to get to 3,300rpm, high RPMs, that should be about 30MPH
If its starting to "crapping out" over 2,500rpm(20-25MPH) you do have either low fuel pressure or Clogged exhaust
Your best power with this engine will be between 2,300 and 2,900 RPMs, peak is 2,600rpms
If you don't have a tachometer that's not a big deal, engine can REV to 5,000rpms so you won't hurt it by REVing it up high for testing
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
177 CID
Eaisest way to check is take it out for a freeway run at night for a few miles and see if the cat is glowing red.
Something is wrong. A 2.9 will bury the speedo even with an auto.
ropinwillie
5
Sublette, ks
Damn guys I really appreciate the help!!! you all are pretty damn awesome in my book. I'm definitely going to check in to it thanks for the help
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
Has it always been this dead or did something change? Are you timing it without unplugging the spout connector? A 2.9 may not be a rocket but you should be able to go way more than 65.
franklin2
1,758
Virginia
A 2.8 is a lot weaker than a 2.9 and my 84 BII with a 2.8 and 5 speed cruises nicely at 75. It will go higher than that, it will peg the speedo which only goes to 85, but that is nearing the max on level ground.
ropinwillie
5
Sublette, ks
Ok you've lost me now what are talking about when you say unplugging the spout connector?
ropinwillie
5
Sublette, ks
Welcome to TRS :)
It matters, alot
I have darn near zero response at anything above 2000 rpms so I'm thinking the cat is likely the problem definitely going to look into it this weekend. I really appreciate your help 👍
