Will a 3.8 v6 bolt up to a m5r1 transmission in a 99 ranger.
crazyman2006
Alabama
I have a 99 ranger 2.5 manual and an 02 mustang 3.8 automatic. I would like to put the 3.8 in the ranger. Will the 3.8 bolt up to the m5r1 manual transmission? I know I will need a flywheel and clutch.
don4331
1,354
Calgary, AB
5.3
No, the 3.8 has the same bolt pattern as the 5.0, so the 2.5 manual won't bolt up
However, the 3.8 will bolt up to the m5r2 as found in F-150s (once you have included the required flywheel and clutch) .
pjtoledo
3,006
Toledo Ohio
Fords
3.0 2.3
there are 2 different bell housing patterns for the 3.8
small block, & FWD
the FWD is the same as a 3.0 Vulcan
neither match the 2.5
don4331
1,354
Calgary, AB
5.3
small block, & FWD
But does the FWD 3.8 bolt into longitudinal mount? At least the RWD version bolts in like an Explorer V-8.
pjtoledo
3,006
Toledo Ohio
Fords
3.0 2.3
good question.
I had a 3.8 block from a '95 taurus and tested the bell housing.
don't remember what the motor mounts looked like, and disposed of that block a few years ago.
EDIT: found info that says they are different
and... there are 10 different 3.8 blocks
superj
2,714
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
Amd tou can always make a mount to fit
