Why is there no fluid?
90rangersuper
Pittsville,WI
Just got a question, on the a4ld, where the output shaft joins the t-case, in the void in there, there was ATF fluid in there on the automatic but on the m5od there is no fluid in there, wondering why this is different or is something not right
thanks
mhughes165
9
302
the outpust shaft seal on ur m50d is good, there shouldnt be any fluid in there as the trans and t-case use different kinds of fluids
90rangersuper
Pittsville,WI
thanks, just wondering about that. I thought the m5od and the 1354 both used ATF though
mhughes165
9
302
i may be wrong, and someone please correct me if i am, i thought all transfer cases used gear lube??
MAKG
19
California central coast
No, that's not correct.
All RBV transfer cases use ATF.
For unclear reasons, the M5OD has a clear cavity (with a drain!) between the transmission and transfer case. I believe the FM146 does as well. The FM145 and TK4/5s do not; there is gear lube right up against the front of the transfer case.
90rangersuper
Pittsville,WI
thanks makg, you've cleared up lots of confusion for me lately
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Basically most t-cases that have an oil pump inside them use ATF
T-cases that use gear oil are generally "splash" lubricated.
Yes, the M5OD has a seal, but those seals are prone to leaking
the real problem is that someone thoughtfully put a sipe groove
in the Trans-to-tcase gasket surface so that WHEN (not if) the
seal fails that the oil can actually escape all the way to the ground...
that is why I strongly recommend SEALING that groove with a blob of silicone
When the seal fails if the other escape is blocked worst case that chamber allows
less than a pint of fluid to escape into it and then the oil loss stops.
AD
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
FM-146 also shits gear lube when the T-case is pulled...
racsan
4,505
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
its awfully funny there is that machined groove there, and a gasket. why have a gasket when you have a oil escape groove?
________
iolite vaporizer review
90rangersuper
Pittsville,WI
when i pulled the t-case off the a4ld that atf in the cavity just about landed on my face, missed me by an inch, i didnt seal the cavaity though when i put the m5 in, i am looking for a 1354 manual, i will seal it then hate that pos touchdrive
AllanD
TRS Technical Staff
135
1987... sorta
'93 4.0
On my personal transmission that sipe groove has a drilled and tapped hole into which I threaded an aluminum bolt smeared with epoxy then cut it off flush with the gasket surface.
it WILL NOT leak.
AD
