What's the easiest way to sharpen a chainsaw chain?
blue83ranger
IL
302
I need some suggestions on the easiest way to sharpen a chainsaw chain without just taking it somewhere or buying a new one. For some reason I just can't seem to figure out how to get a chain as sharp as a new chain is. The best luck I've had is with an electric sharpener that hooks to 12 volt but it was a china one and the stones didn't last to long and just fell apart. So, any suggestions on a sharpener? Has anyone tried a Timberline sharpener? a Granberg Bar-Mount Chain Saw Sharpener? or a Husqvarna Sharp Force Chain Saw File guide?
Frank The Tank
43
South
El cheapo 110 plug in sharpener from harbor freight mounted to a 2x4 is all we use at work.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
I just have a file and guide set I sharpen mine by hand. I also have a stone and guide that goes in my Dremel for using at home. The stones do not last very long, so I just use the file at home most of the time as well.
4.0B2
151
Walls, MS
4.0 v6
I just use a file.
blue83ranger
IL
302
I've tried a file with and without a guide. Sometimes it seems like it doesn't do anything then other times it does make a good difference but nothing close to how new chains are. And I have the right size file and I have the correct angle on it. I'm not sure what I'm doing wrong.
kimcrwbr1
46
maplevalley WA
2.8l
http://www.ebay.com/itm/T10278-Chain-Saw-Filing-Guide-Grizzly-Industrial-NEW-/281154939518?pt=LH_DefaultDomain_0&hash=item417623ea7e
I just use a sharp fine round file you can get at any hardware store. Once you find the right size file them all evenly getting the angle right just file them all until you can feel the burr. Then take a fine flat file and measure the rakers with a flat edge across the top of the teeth you should see about 1/32 inch light above the raker. That is the curved thing between the teeth. This is one of the many type guides you can use.
kimcrwbr1
46
maplevalley WA
2.8l
If you dont file the rakers down the teeth dont take enough wood to cut properly.:icon_thumby:
blue83ranger
IL
302
I bought one of those gauges too, but currently the chains on the saws I use have only been "sharpened" 2-3 times. But I did check the rakers and they were within where they should be.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Are you filing down each tooth in equal amounts? Meaning say making 5 strokes on each tooth? You also need the file guide so you can tell if the rakers are too high if so they can cause kickbacks and improper cuts, along with making it feel like the chain is dull.
How old are your chains? You may need to start with a new chain, then as it becomes dull sharpen it using a round hand file the correct diameter for your chain. Not all chain teeth have the same diameter teeth, so you need to match the chain and file.
For example the chain on my chainsaw uses a 3/16" diameter file, using any other size file will render the chain useless as you start filing the teeth wrong and pretty soon they aren't cutting.
Maybe this video will help you as well. This guy has a lot of very useful small engine videos as well.
http://www.youtube.com/watch?v=-PTXj1VIlbc
blue83ranger
IL
302
I bought a gauge and file in a set for just the rakers and have used the gauge but never had to file anything. and I do file the teeth that do the cutting all an even amount. My chains are no older than 7 years old. But I use up to 3 different saws. and my pile of wood for winter is just a 1949 f-4 flatbed full of wood even with the top of the cab and a trailer about the same size with no stakes to hold the wood on square. So it's not all that much wood.
scotts90ranger
4,371
Dayton Oregon
2.3 Turbo
The harbor freight electric sharpener is worth the $30... do it... I mounted mine to a 6" long 2x4 and stick it in my vise when I need it, stick it on the shelf when I don't...
