what up Cali in da house
jbj1162
san leandro Ca
ford range
I have a 99 ranger 2wd got in truck the other night turned key all that happened was one click, inside lights /buzzers / stereo all work . checked starter & its good I need some guidance please
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
The battery cables are not loose, right? Sometimes they are not right and won't make a good connection and all you get is a click
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Welcome to the site. As said above, Check the cables for corrosion and tightness. Then test the battery or have it tested at the local parts store. If all is good, test the starter relay.
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Yep... corroded battery wire connections. Dont forget to check starter +ve and engine ground as well as battery.
I've had a positive cable hanging on by a couple threads behind the insulation, made it hard to diagnose.
8,370
If automatic trans try shifting to Neutral first then try to start engine
If manual trans then clutch pedal has to be down to the floor
Its a safety thing so starter will not activate if vehicle can lurch forward or backward
On Ford column shifters the bolts get loose so lever can't get trans all the way into Park so no starter motor, try neutral
1999 Rangers with V6 engines(3.0l or 4.0l) have PATS(passive anti-theft system)
If the "transponder" key in ignition can't be read or is mis-read then no starter motor
BUT............
There would be a rapid flashing THEFT light on the dash if that happens, and you don't mention that
