TheTopher
- Dec 8, 2008
- 176
- Delaware
- Ford
- Engine Size
- 2.3
First and foremost, anybody who says big brand companies are more reliable than home built machines and are easier to service needs to stop buying cheap parts.
Now that we've gotten that out of the way...
my laptop is an Asus EEEpc 1002HA that serves its purpose quite well. Had it about a year and a half.
My desktop is nothing too special. It's built with a watercooled Intel C2D e7400 processor, Coolermaster PSU, Gigabyte p31 chipset motherboard, eVGA GeForce 9800GT, 4gb of G.Skill DDR2 1066 (WinXP can only read 3.33gb though) an SB Audigy for the sound card, all in a custom modified Lian Li PC61 case.
My real pride and joy though was my old gaming rig, which I sold to a buddy of mine after I stopped having a lot of time for video games. I wanted to see it go to somebody who'd use it.
Bear in mind I built it about three years ago, so most of the parts are outdated by today's standards.
It had a Intel Core 2 Quad Q6600 g0 revision processor running at 4.1ghz (stock clock, speed was 2.4ghz), 2gb of memory (Quick lesson kiddies, more memory than your system's going to use actually slows it down) OCZ 900watt PSU, a pair of Raptor 74gb 10,000 rpm drives in a RAID0 a BFG Geforce 8800GTS (g92 core, 512mb) video card, an Abit p35 motherboard in a modified Lian-Li PC65B Case. For the cooling system.... I had modified the motherboard by pulling off the heatpipe and replacing the stock TIM with arctic silver ceramique and then replaced the plastic mounting clips with bolts. On the video card I used a Zalman VNF1000 for the core and a custom billet heatsink from petrastechshop.com for the video memory. For the CPU I used a D-tek Fuzion waterblock connected with half inch ID hose to a 3*120mm cooling tower mounted on top of the case, which had the heat drawn out of it by 3 120mm Delta fans pushing a max of 190CFM a piece, all controlled by a custom built rheobus controller from performance-pcs.com For the DVD drive, I pulled the original bezel off the drive and then cut the side flanges off one of the drive bay blanks from the case. Then I mounted it to the end of the drive-tray and added shims to make it rest against the release button. Now you just touch the faceplate and the drive pops out
Here's just a few pictures...man I miss this thing.
When I first built it, it was running a pair of 8800GTS 320mb video cards in SLI, an eVGA 680i motherboard and only had a 550watt Mushkin power supply and the CPU topped out at 3.6ghz
The system put such a load on the power supply that the 12v rail was only putting out 11.03v It was still rock stable (tested via 24 hours of prime95) I eventually switched to the p35 chipset motherboard and gave up SLI in an attempt to raise the CPU clock speed. Between that and the 900w power supply, I finally got it up to its final 4.1ghz
