2.3L ('83-'97) What is this?
takopolicia
Louisiana
Mazda B2300
I need to know what the heck this thing is and if I can make a block-off plate for it.
66377
66378
66379
scotts90ranger
4,442
Dayton Oregon
2.3 Turbo
That is the oil separator for the PCV system, I would not recommend blocking it off, if anything it needs a bigger one...
racsan
4,495
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
block it off and youl could blow seals, thats how the crankcase breathes. the pcv valve fits into the top of it, air is drawn into the engine by that hose on top of cam cover that goes to the throttle body.
sgtsandman
Aircraft Fuel Tank Diver
12,718
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I also helps keep oil vapor out of your intake. Not as good as a good catch can system but better than what most engines have.
takopolicia
Louisiana
Mazda B2300
Thank you! Do you have any recommendations for a bigger one? aftermarket?
takopolicia
Louisiana
Mazda B2300
thank you!
scotts90ranger
4,442
Dayton Oregon
2.3 Turbo
I might have miss spoken... It's too small in my application (with a turbo...), without a turbo I doubt it's a problem unless you are doing something goofy :)
