1990RangerinSK
1,312
Saskatchewan, Canada
Thanks for mentioning that. Don't know how I missed it. :eek:
Now that raises a few questions about the drag racer... Why is he running a Ranger body?
Because he can? But, let's ask @Maritime Drag Racing for the official answer. It's his truck.
ekrampitzjr
1,092
Virginia
The 4.0 uses 5w30 due to the design of the oil pump and it's inability to maintain adequate oil pressure at operating temperature using 5w20. That engine design comes from a V4 designed in the early 60s. It's big, fat, inefficient, and clunky when compared to the newer engines. Don't compare it to the engines in modern vehicles. It's summer now, so a 20w doesn't matter. A 50 weight is excessive. 5w20 or 5w30 is more than adequate. There's much more to engine lubrication than the weight of the oil. You not only want the oil to maintain a film between moving parts. You also want it to flow between the parts to cool the bearing surfaces and be able to reach all the components in the valvetrain.
Agreed on all counts. I said no way am I going with xW-20 in my 4.0 Ranger because it's easy to imagine some auto shop pulling the same thing as the other poster reported. (But I change my oil myself anyway.)
Some people run heavier oil than specified thinking they're protecting the engine better or they're slowing leaks and oil consumption. My experience has been, if the engine leaks or burns oil that bad, running 20W-50 instead of 10W-30 makes little difference. It won't help. Time for an overhaul. Also, if the higher-viscosity oil doesn't pump or flow properly, it could cause real harm.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,788
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I stick with what the oil cap says is supposed to go in it. Honda at some point had switched from 5W-30 to something thinner as a recommended oil for that engine. Not sure why and didn't dig into it. Then engine ran fine and had good oil test results with the original viscosity.
889
Sydney, Nova Scotia, Canada
355 Chevrolet
2" drop rear shackles
27 X 5 X 15 Hoosier front - 9X30 Hoosier rear(slicks)
Race it - Break it - Fix it - Repeat
In case you wondered why my Ranger has a SBC it's because I already had engine/trans since the 1980s and I bought the truck as a roller for only $1000 CDN with the ProStar wheels, gauges, radiator, fuel cell, SBC fenderwell headers and even a good battery. I think the Ranger is a way better truck for drag racing than an S10 - more room under the hood, tougher suspension, and way better visibility for watching the guy in the other lane. I wuldn't trade it for dozen S10s.....
ekrampitzjr
1,092
Virginia
MDR, didn't know you were on the forum!
Wouldn't a pickup body be too light in the rear for drag racing? Or doesn't it make much difference?
superj
2,706
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
i was wondering that too, the rear end being lighter. i see lots of people run trucks though so there must be some suspension magic going on that doesn't happen on regular trucks used as daily drivers, ha ha ha, because my little ranger just spins and barely grabs if you rev it and pop the clutch
Blmpkn
Toilet enthusiast
6,381
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
It's all about that weight transfer and sticky tires.
Tons of fast pickups out there.
sgtsandman
12,788
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I finally got around to getting the engine oil, transmission fluid, and transfer case fluid changed (a month late). I still have to do the brake inspections and rotate the tires but I didn't have the time for that today. I did get to lube the leaf spring bolts. I forgot to look at the spring packs though and see how many pads need replaced. I know there is at least a couple that got pretty mangled up from the last trail ride. But at least the preventative maintenance is getting done finally.
Spidey300
24
St. Louis, MO
2.5 (4 Cylinder)
225/70R14
Last night I finally replaced my spark plugs and wires on my 98 2.5L. Haven't changed them before and the #3 wire boot on the passenger side was partially melted and visibly arcing/ticking while running.
Boy, that was not fun. I had the wobble extensions, etc. so the actual plug removal and install was the easy part. One of those flex cable claw grabber tools actually worked great to feed the plug down to the socket and get it started. Getting the wire boots off #3 and #4 on the driver side sucked. I didn't have a long enough pliers and they didn't have the plastic handle covers on them. When I finally got #3 boot off, the metal inside of the plug boot stayed on the plug so I couldn't get my deep socket on it so I had a heck of a time with that. Then #4 did the same thing. Luckily, my wife doesn't mind working on cars and has small hands and came out to help.
Snaking the new wires and boots with the plastic puller handles on them was another pain for #3 and #4. It was almost impossible to get them turned into position and lined up properly. I'm still not sure I got them pushed back on all the way.
Anyway, I was up til 1am and this morning I ordered a set of 11" long reach needle and ring nose pliers, lol.
racsan
4,503
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I tried fixing a couple escape spare tires, put the green goop in them, bolted them in the back of the ranger & went for a ride. they still leak, rust between rim & tire on one rim and between valve stem & rim on the other. Now im using the tailgate as a workbench , goung through my work toolbox, taking out stuff I never use, getting rid of all the extra fasteners that Ive collected (and never seem to use). Next I will probably head to town for some topsoil. got gas last night, almost $40 and wasnt even at half a tank yet. I remember when 20 was more than enough, and I had a smaller tank with a bigger engine too!
17,972
SW Iowa
JoshT
1,834
Macon/Fort Valley, GA
Spent money and added another parts truck (sorta) to the stable. Gotta figure out where to host pictures at these days and I might get some posted.
EDIT: I guess I could use the forum's media gallery for now.
sgtsandman
12,788
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Those driver's side plugs are a real bear for sure. Been there. I think the 2.3 engines are the same deal, at least the dual plug versions.
sgtsandman
12,788
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Got all the preventative maintenance done on the 2011. For a 12 year old truck, she's holding up pretty good, though age is starting to show. The front, passenger side brake splash shield has separated from the knuckle and the driver's side is partially broken off. Time to do something about that.
The parking shoes are showing their age now too. The passenger side, upper shoe material is delaminating from the backing. So, I have to get those and a new set of hardware on order for that as well.
racsan
4,503
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
My front brake splash sheilds are long gone. Today I really used my ranger, took the cap off and went to menards. 2 trips actually. 1st trip was 6 bags topsoil, 14 bags mulch, 56 12” x 3” paver things and 2 hanging baskets. Trip 2 was 12 bags river rock and 15 (more) bags of mulch. I did get the garden in before todays rain, so even though I still need to do the mulch & concrete borders around the maples lining the driveway I am still calling today a success. Got home just before the rain.
