snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
9,846
Jackson, NJ
'79,'94,'02,'20
All Fords
I reject this^^^ answer and replace it with my version of how they got it there.
You’re the 2nd person to say that... it must be true.
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
racsan
2,777
central ohio
2.3/140-4
225/70/15-winter. 235/75/15-summer
built, not bought
I unloaded 1/2 the truck tonight & did the mulch with concrete surround around the 7 maples lining the driveway. Its no longer dragging the mudflaps on the pavement. Handling should be better on tomorrow’s drive to work, its been awful the last 2 days with all the weight thats been in the back. I still have 12 bags of river rock & 7 bags of mulch. Those concrete peices were the real weight makers, 2” wide , 4” tall , 12” long. Not sure what they weighed each but I had about 45 of them and they were at the very back increasing the leverage.
Vindictus
68
NewBrunswick
4.0 SOHC
I granaded the emergency brake drivers side leaving work tonight.:(
Now i get to pull the axles. I love learning on the fly as I have never had a rear end apart before
ericbphoto
Overlander in development
Forum Moderator
9,054
Wellford, SC
6"
Why do you have to pull the axles? E-brake stuff is external.
What, exactly, broke?
Oh, wait. I see you have a 2011. I'm not as familiar with the disc brake rear axle e-brake assemblies.
1990RangerinSK
1,048
Saskatchewan, Canada
If the exhaust is dumping under the bed, the loudness increases a lot.
Rerouting it to dump, just in front of the rear tire reduces the noise but still increases it over stock.
To each their own. I like mine quiet. As long as the person in question isn’t waking up the neighborhood early the the morning, I don’t care.
You'd have loved my '91. You could hear me downshift a mile (or more away). I sometimes had fun setting off car alarms.
EdgeRanger91
22
virginia
Ranger Edge
4"/2"
so in my 02 edge, I sitched, cleaned, install fx4 lvl 2 red seats in(bucket) installed the mini floor console, I had a set of Firestone Destination LE3(235/75/15) installed on a cleaner set of alloy split spoke wheels, I fixed my cruise control buttons with new ones, I replaced my oil, filter, and air filter, and battery, T bar lifted the front of my truck by about an inch and ahalf, oh, and I got some Ranger seatbelt pads I put on.
Bill
464
Sacramento, CA
Sprayed the MAP to see if it would help with the goofy idle problems I've been having, then drove it to fill up with $5.34 a gallon gas. The end result of all this is I still have idle problems and now I have a $66 hole in my wallet.
I think I'm going to check the spark plugs. Maybe replace them and the wires to see if bad spark is causing this problem. Here's something odd that I noticed when pricing spark plugs earlier. The original plugs were ITR5F13 plugs. They were worn, but I could tell the original gap was about .050, and that is what NGK states the spec is for that plug. The manual states the gap should be .049-.054. The replacements are pre=gapped at .044 and state they can't be gapped. This goes for the Motorcraft plugs too. Does anyone know what is going on with this discrepancy?
ekrampitzjr
204
Virginia
Plenty of "pre-gapped" spark plugs are actually out of spec new in the box because of sloppy handling during shipping and stocking at stores, so they have to be re-gapped. Any conventional plug can be re-gapped. You just need the correct tool and some care. Use the type of tool that has a hole the end of the ground electrode can fit into, so you can use leverage to gently bend the electrode by hand without touching any iridium or platinum tip on it. Do not use a tool designed to put pressure on those tips.
I checked the gap on the Denso plugs that went into my Ranger last year. Most of them were close, but I made sure all were set at the low end of the specified range, to allow for the gap to get larger over time but still stay in the range. These plugs have small platinum-iridium tips, but my tool didn't touch those.
superj
694
corpus christi, texas
ranger edge
V6 of power
none
none
235s
Grew up in the 70s, 80s, and 90s
i have been driving the ranger to work yesterday and today because of rain.
sgtsandman
Aircraft Fuel Tank Diver
Forum Moderator
6,040
Aliquippa, PA
Ford Ranger XLT
4.0 SOHC
Pre-2008 lift
31X10.5R15
I wake up for work at 0430-0500 in the morning. Most times I’m already on the road before the masses (or the snow plows in the winter).
Non-drill weekends, I get to sleep in and get real grumpy if that gets interrupted.
racsan
2,777
central ohio
2.3/140-4
built, not bought
I sunk mine to the frame , not sure if I should try to excavate it, call for a rollback with a winch, or just wait it out a month once its fully dried. Bad thing is that puts us down to one vehicle now. And of all 3, its the hhr. The escape is waiting on rear axleshaft/swingarm bearings. If I thought my ford tractor would get it out Id do it but Im doubtful. A 4x4 F150 couldn’t.
Uncle Gump
Forum Moderator
7,657
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Lead, Follow or get out of my way
:worthless:
alwaysFlOoReD
Forum Moderator
2,887
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
A lever... an upright 4x4 post on top of some plywood and the winch cable over the top of the 4x4. This lifts the truck up before pulling it out.
Fair warning.... I've never tried this in this particular situation.
Uncle Gump
Forum Moderator
7,657
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
:worthless: :worthless:
Forum Moderator
12,076
SW Iowa
Tractors don't play fair. Go for it.
