tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6ā€ skyjacker 2ā€ body
33x12.5
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
It's the manual 5 speed out of an 83 4x4 ranger, the one that takes gear oil. The shifter on my truck currently A 2.3 4SPD 4X4 MANUAL has the same shifter
So where did you get the M50D. Isnā€™t that what you are claiming the nice red painted on is? I have one but itā€™s in the rain now. Iā€™m curious if yours is a M50D
ThatOneGuy
575
South sound
Ranger Explorer
Explorer is 4.0 ranger is 2.3 soon to be 4.0
Let the universe take you where it will !!!
It came out of a 93 explorer sport I took it out myself infact I bought it for the trans lol.
17,972
SW Iowa
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Ok. So I have an M50D from a 94 explorer I bought for the same reason mated to the 1350. She in the rain now so I climbing under there. I can make those measurements tomorrow and compare them to yours. It may well be your transfer case but seeing is believing. As for your clocking. Your 2H looks the same as mine.
The first pictures you posted it appears the shifter is setting in neutral and the transfer case is 2H. Makes it look like it would be correct if they made contact. Iā€™m wondering, after all the photos and hubabaloo that maybe the shift lever on your case is shorter in length.
17,972
SW Iowa
Ok. So I have an M50D from a 94 explorer I bought for the same reason mated to the 1350. She in the rain now so I climbing under there. I can make those measurements tomorrow and compare them to yours. It may well be your transfer case but seeing is believing. As for your clocking. Your 2H looks the same as mine. View attachment 67664
It is shorter and clocked slightly different. I tried cutting down and welding my a4ld one and it didn't work.
snoranger
Professional money waster
ASE Certified Tech
13,724
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
l today I recieved the transfercase shift linkage kindly provided by @tw205. I guess I should have test fit it before I made it look great.View attachment 67648View attachment 67649
Why am I having such a hard time finding the right shifter, this is closer than the one I had, was there never a 1350 manual shift behind an m50d, is this my issue. No blame on tw205 as far as we knew it should have fit. Does anyone have any idea if the shifter I need exists. Should I just give up and use the 1354 elec.shift
The early 13-50s had the non-removable arm on the shaft... IIRC, they were about 1ā€ shorter than the one used with the M5OD/A4LD. Youā€™re going to have to modify the either the shift linkage or the arm on the T-case.
Are the bolts that hold the T-case to the trans standard or metric?
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
I see it. I blew up the pictures of his and mine. His Clocking looks like 1030 mine looks like 10. Interesting. I hope you arenā€™t offended by my inquiries. I really like gaining the knowledge. Donā€™t know what Iā€™ll use if for but hey, itā€™s a hobby.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Curiosity question. Are the shafts interchangeable from those early 1350 and the later ones?
snoranger
ASE Certified Tech
13,724
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I donā€™t see why not. Hell, You can put a 13-50 manual shaft into a 13-54 electric case if you drill it and shave about 1/4ā€ off the case.
scotts90ranger
4,482
Dayton Oregon
2.3 Turbo
CEL came on last night on my way home, said cylinder 2 misfire> Dug into it this morning and found the passenger side spark plug wire not pressed into the coil for cylinder 2... had been going on long enough to eat away a good portion of the coil connector, I spent 10 minutes looking for my spare coil without luck but once the wire is clipped on it should work ok for a while... while I was there I changed the front two drivers side plugs and wires since I didn't do that last year, so now it actually does have a spare already installed :)
17,972
SW Iowa
Drove it to work for the first time in like two weeks since deer are getting Stupid and it is dark for my commute now.
On the way home I picked up our two year old from my parents who were baby sitting. Did a little engine braking in a tunnel with the windows down (not actually trying to do anything) which netted a nice snap crackle and pop and heard a "wow!"... "truck!" from the passenger seat. I went ;missingteeth;
racsan
4,503
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Mine pops quite a bit too when I let off the gas to slow down, especially with the flatbed hitched up behind me.
17,972
SW Iowa
I hear a lot more backtalking out of it without the topper. Apparently it isn't quite as tame as I thought lol.
ThatOneGuy
575
South sound
Ranger Explorer
Used it to haul off some garbage. Working on fabricating a transfercase shifter for the future m50d 1350 combo
