Welding cat to muffler at flange?
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
So I can't for the life of me get the muffler flange to seal tight to the cat ouptut flange on my 89 Bronco II. I have tried a variety of gaskets to no avial - it alwasy leaks out of the bottom where the two flanges meet. Can anyone thing of a reason not to just weld the two together?
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
I can think of a reason. But the reality is, if that’s what you have to do, then that’s what you have to do. It just means that you might have to cut it apart some day.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
my only worry is that I believe that joint is suppose to flex. If I weld it, the stress will be where the y-pipe connects to the cat. That is a strong ass flange point though. I dont know, I think too much
ericbphoto
16,598
Wellford, SC
3.0L
6"
If the joint is loose enough to flex, its loose enough to leak. If you want a place for stuff to flex, install a piece of flex pipe.
BlackBII
Ranger Custom
Truck of Month
982
UT
I replaced that connection on my Ranger with some header collector flanges. It's been working great.
Patriot Exhaust H7259 is what I used. It's for 2.5" pipe, but I was able to get some pipe reducer adapters at Autozone since the factory pipes aren't that large.
19Walt93
4,467
Canaan,NH
351
3"
235/55R16
I like the bell flare connectors Walker makes better- no gaskets and you can swivel it around to suit you. I weld the male end of the connector to the pipe in front and the female end to the rear section but you could switch it if you want. I couldn't find a picture of the male end but the lower right piece is the female end. No more leaky gaskets.
39069
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
I think this might be the solution. I could weld the one on the bottom right to the muffler and use a donut gasket and spring bolts.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
You dont use a donut with that setup if you use both the male and female end. Its self sealing like a compression fitting.
