WATER POURING OUT NEAR THE BACK OF ENGINE SOMEWHERE
shetries2
Tacoma,wa.
b 3000
HAS ANYONE HAD THIS PROBLEM IT DOESNT APPEAR TO BE ANY HOSES MAYBE A FREEZE PLUG OR DID I CRACK THE BLOCK OR SOMETHING
Need more details.
8,370
Was the Air Conditioning(AC) on?
If so, Water will come out on passenger side behind the engine, not Coolant, water, its from the AC evaporator, can be quite alot if its humid outside
ALL CAPITALS IS CONSIDERED SHOUTING, so turn caps OFF, thank you
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I DON'T KNOW CAUSE YOU DIDN'T TELL US ANYTHING!!!!!
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
That always happens for a while right after you pull the truck out of the lake.
shetries2
Tacoma,wa.
b 3000
Sorry, I don't do this much and dislike typing. I was driving a lot yesturday didn't seem to be overheating ,came to smell antifreeze, didn't notice any steam ,went in ,came out and could see liquid draining all under the engine and tranny connection area. popped hood checked the oil ,good. checked expansion tank and it was still full .felt the top hose and heater hoses ,hot noticed my thermostat gasket was leaking took it out tested it works my water pump may have gone bad check it tomorrow
Colin
182
ON Canada
Mazda
4.0 OHV? My old truck had the lower intake gasket fail and it had a pretty serious leak out the back
Well his profile says its a B3000, those usually have 3.0s.
Colin
182
ON Canada
Mazda
Ah I'm on my phone can't see that, it would be helpful if the op would post their truck info in the thread
ericbphoto
16,598
Wellford, SC
6"
If you turn the phone sideways, the profile info shows up.
Colin
182
ON Canada
Mazda
DCman
14
Poulsbo, Washington
Ford Ranger XL
2.5 (4 Cylinder)
P205/75-R14
Can you still wipe the ground where the fluid leaked and tell us what it is? (is it actually coolant?)
