rfl
- Mar 17, 2011
- 0
- Utah
- Ford
- Engine Size
- 4.0
I have read a bunch of posts on this topic. Some seem to discuss specific things that may or may not be related to a '93 Ranger (like a fuseable link off the engine compartment fuse box?) so I am posting in hopes that someone can narrow down the troubleshooting to this year truck.
The issue...
Alternator bearing let go, replaced with with a new from Oreilly - before someone piles on, it was either Oreilly or Autozone. This was a parking lot swap at my sons school. Simply nothing else available other than non-Motorcraft remans from the same 2 locations. When replacing the alternator, we also threw in a new idler since it was already known to be low on resistance. Belt is new. Truck fired right up.
Next day truck fires up in the morning, but battery is dead later in the day. Thought it may have just had a weak charge from a week worth of short trips so charge it overnight. The truck makes it through the next day but dies on the road that night. We jump started the truck and drove it home with the lights off. Thought maybe we got a bad alternator so took it back and got a different one.
Next day starts off with a fully charged battery and second new alternator. After a short drive the gauge is dipping so we load test the battery. It is bad, so replace the battery. After replacing the battery the gauge was hanging around 10, so told my son to take it for a drive to see what it does. He went about 60 miles out with the lights on, not much change in the gauge. One the way back the gauge dips a bit more. He stopped an let it idle and it dropped even more.
All the ground connects are clean. Engine was swapped less than 1,500 miles ago and all engine harness were unwrapped, inspected, and rewrapped.
The battery terminals are new, but while it looks fine I have been a bit leery of the ground multiple wires running to the a single aftermarket terminal. Everything looks tight, but...
So where do I go from here? Does the Ranger really need 4 wires going back to the battery ground or can I run some of those to the chassis? What fuses are involved in the charging process on this thing? Bah!!!!
The issue...
