V8 driveshaft torque capacity (not fitment question)
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
So, what are all you guys (with 400+ hp) using for a driveshaft? The factory 2.3L shaft in my '93 longbed held up to a mild 302. I am however concerned with the 331ci stroker and a built hard shifting C4 transmission. Anyone have any input? I'm considering having a custom aluminum shaft built, but I've never dealed with a driveshaft shop before so any recommendations would be welcome.
So, what driveshaft are you guys running and how much power is being put to it?
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Well, guys using 4wd low are putting more then twice the torque a 2wd would be through their shafts without issue, especially those with an 4wd/v8 combo.
But, I've broke mine after belly dropping the truck on it so I had one built. The stock ranger 1 piece driveshaft is .065 wall tubing, and I had my parts shaft (lengthened from an explorer) retubed with .090 wall, and haven't had an issue yet. I'd think a higher quality U joint would be a better expenditure/failsafe then a custom built shaft.
*** Increasing diameter will also increase strength significantly.
baddad457
18
Opelousas La.
I ran the stock 2 pc shaft in mine for several years behind a manual transmission. Wasn't til the 331 came and I subjected it to a dry burnout on rough pavement that the middle cast yoke broke. That was the only part that broke too. I replaced it with a shortened (by 2") shaft from a 93 E150. Only drawback to it is it bumps the floor of my 89 Supercab when the truck has 2 people in it.
847b
Vancouver, WA
Definitely upgrade the u-joints...
I will measure my steel drive shaft when I get a chance. Whatever mine is, it has stood up to 4 seasons of drag racing with a transbrake, 3500 stall converter and 350 hp to the wheels.
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
Well the stock 2.3L longbed shaft I have is right around 4 inches in diameter (this is from a poorly calibrated eyeball). I remember first doing the swap thinking "this driveshaft is a little overkill for a 2.3L". I've already got top quality joints in it from when I put the first 302 in. I think I'll just run a driveshaft safety loop for added security against potential body damage. Then again, I might eventually have a custom shaft made because I've been tossing the idea of a centrifugal supercharger once I get the 331's issues straight.
Thanks for the input!
847b- what have you found to be a weak spot in the frame? I noticed with the 302 the chassis would flex by the bed a lot. I'm thinking some cross bracing and ladder bars.
Mac
183
C. Wisconsin
2000
199
Hope you're taking a lot of pictures to tease us with.! Would sure think that shaft would do. You've upgraded the joints and going to run a C-4, it's normally the shock load that takes the joints out. Don't see a problem even going with that charger.
Dave - Up Nord
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
Dave - Up Nord
Easy big fella, no boost yet. I'll try to take some pictures. As a matter of fact, I'm going to be cutting up some long tube "in frame" headers to fit the ranger chassis (not a big fan of shorties and not going to pay $+400 for long tubes). Maybe I'll snap some pictures of that to satisfy your craving. Wait til spring when its warmer. I'll make more progess then.
baddad457
18
Opelousas La.
If the stock shaft is that big, then leave it be. It'll do.
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
My 98+ stock replacement was 3.5" dia, the one I replaced it with (same dia. as original 2 piece) is 2.75" dia.
847b
Vancouver, WA
My drive shaft (1 piece) is 3" OD steel tube. Not sure on the wall thickness and I can't find the receipt.
I have not found the weak spot yet. I have a four link rear suspension and to mount the front brackets I made a heavy duty cross member out of 2" x 6" x .188" steel tubing and 1/4" plate. In addition, I also added a cross member behind the rear axle to mount shocks to. These two items really stiffened up the back. While under construction I did notice (as you mention) how flexible the back half of the frame is. I think cross bracing would be a safe bet and get the truck to hook better. Hope this helps!
Mac
183
C. Wisconsin
2000
199
Don't get me wrong but you have a nice rear end! Some guys just cut and hack and make something fit, a lot of you guys take some pride in your work and it shows. --------------- Brain working. Seem to remember a narrowed 9" 31 spline sitting in the gargage. Came out of all things a Pinto.
Dave
Iron Ranger
Run lil' ricer RUN!!
MTOTM Winner
22
Minnesota
0.040 punched 302
I believe mine is either a 3 1/2" or a 3 3/4" one piece driveshaft I had custom made by a local driveline shop for $185. It's much better than the wimpy 2-piece(which I think was 2 3/4" dia.) Even spritzed for the Spicer joints.
This is definitly one area you don't want to cheap out on. I didn't have a lot of money at the time, but I knew that it would be well worth it.
originalnitro
West Blocton,Alabama
347
I twisted a stock 1 piece into at the rear joint wth 462 rwhp. I would go custom when/if you supercharge it.
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
Get some .250 wall high-carbon seamless pipe.....then go to the Jon Deere store & pick up a couple 7" (cap to cap) u- joints.....give the U-Joint shop 400 $ and the dimensions.....problem solved 4-ever.....
now.....about the weak tranny & differential !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
baddad457
18
Opelousas La.
:nono:Are you off your meds again ? :icon_rofl:
