Hardwareman
- Aug 7, 2007
- 0
- SoCal
- Ford
I think I may have found my problem!
I followed your guys advice (thank you very much btw) and started by checking to see if there was a leak after the MAF sensor. I did'nt find any so I went ahead and removed the MAF sensor. I actually unbolted it from the housing and looked at it. IT DID have dirt on it so I grabbed my can of carb cleaner and cleaned it off.
The Ranger purred after that and the IAC valve even worked. When I disconnected the IAC valve at idle the engine rpm's NOTICEABLY dropped just like it should. The engine rpm's even compensated for the A/C compressor load when I turned the A/C on!
I took it out for a test run and when I got back I disconnected the IAC but the engine rpm's did'nt decrease this time, the engine did however compensate for the A/C compressor load still. Does the IAC valve work only when it need to? Should I test my MAF sensor cause it may be going out?
THANK YOU EVERYONE soooooo much for your help. Especially Joelzme for taking extra time and giving moral support. Actually everyone for their moral support. Now let's just hope she stays this way and I'm not jumping the gun here.
Allen
Allen
