2.3L ('83-'97) Trying to identify part number f57b-14a068-aa
Waldoduhh
9
Lakeland fl
ford ranger
trying to figure out which ranger this came out of. Part number f57b-14a068-aa. I installed power distribution and engine harness from 2000 ford ranger 2.5l thats in this 97 ford ranger
Waldoduhh
9
Lakeland fl
ford ranger
part number goes to interior fuse panel. If you have a 97 through 2003 ford ranger.
8,370
f57b-14a068-aa
F5 = 1995
7 = Ranger
B = body electrical
14A068 = Ford part number for general use, in this case fuse/relay panel, not Ranger specific, not even truck specific
AA = revision of part, AA is 1st revision, AB would be 2nd revision, AC ect.......
F5 does not mean it was only used in a 1995 vehicle, F5 means the previous 14A068 part was changed more than just a new revision so its year was updated to denote the major change
You could find an F5 part in a 2020 vehicle if it was never changed enough to update the F5 designation
In 1999 Ford changed their Year and Model designations, Year is now 1 digit, Model is now 2 digits
1999 = X
2000 = Y
2001 = 1
2010 = A
2011 = B
Ranger = L5
So YL5x- would be a 2000 part number designation for use in Rangers
Waldoduhh
9
Lakeland fl
ford ranger
f57b-14a068-aa
F5 = 1995
7 = Ranger
B = body electrical
1999 = X
2000 = Y
2001 = 1
2010 = A
2011 = B
Ranger = L5
So that would mean this part is compatible with the 2000 2.5l ranger power distribution i put in, and shouldn't have any issues connecting? I put in the right dist block and engine harness, but now I cannot get this thing to crank unless I jump power from the battery to the ignition signal wire now. It won't start either, just cranks when i jump wire.
8,370
No, it would mean its for sure compatible with a 1995 Ranger
If there was a F6, F7, F8, X or Y change then that would be the correct part
Google: f57b-14a068-aa
And change the 5 to 6 and then 7 and then 8
Then try it with XL5 and YL5
If you get a later match then not the same as the F5
Looks like fuse 24 in cab fuse box was used the same on both 1995 and 2000, it should have 12volts when key is turned to START
That 12v is passed thru clutch or automatic Neutral switch, and to the starter relay in the engine fuse box, and that activates starter motor
Check if either coil pack has 12volt on center wire with key ON, that's from fuse 19 in cab fuse box, 25amp
