Trouble codes HELP
dragonboi
I have a 1997 ranger with a 4.0L
it has the codes saying lean fuel bank left and lean fuel bank right
jumps at idle between 500 and 800 very rapidly and dies some times
have replaced air filter, fuel filter IAc and cleaned MAF sensor still codes
help me out please
timstone
check for vacuum leaks...if none are found check o2 sensors
dragonboi
timstone
ok...well maybe check to make sure you are actually getting spark to each plug
Earl43P
38
Farmington, Pa
Ford F250 4WD
There is a wealth of info on those codes, if you used the Search. "P0171 P0174"
Might have a vacuum leak, might have bad upper and lower intake gaskets (likely since it's both banks). Pretty common problem. I'd inspect all the PCV tubing and elbows and replace the intake gaskets if you don't find anything else, like a loose intake tube.
I'd believe the O2 sensors are telling the truth.
modelageek
14
Boston, MA
IT IS NOT YOUR O2 SENSORS!! I agree with Earl. I have seen a lot of posts about the intake gaskets causing the lean codes and also there is a hose with a 90% elbow on it that i have seen cause an issue. I cant remember what year 4.0 it was/is. you also might want to do a fuel pressure test if you have the means.
dragonboi
ok thanks for posting everyone i really dont want to delve into gasket replacement but it looks like i might have too
oh well i need it to run right, its my only means of transportation
