Junk Collector
Truck of Month
- Mar 4, 2008
- Reaction score
- 4,858
- Location
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
You absolutely can get the transmission out and back in without touching the Y pipe. It requires having the vehicle jacked up quite a ways off the ground and you basically have to pull it out at an angle while turning it and then installing it is the opposite. A real pain and a big pry bar will help. I prefer fighting it that way as opposed to messing with exhaust bolts - your call. I usually use a transmission jack to get it under the truck and resting on the radius arm crossmember, then bench pressing it into place the rest of the way.
Automatics can come out & back in like that too but they are substantially heavier.
