mstier
- Dec 20, 2013
- 0
- Ford
I have a 92 xlt ranger that has had problem after problem with the 4x4. The hubs went first, and i put some sturdy manual hubs on. It worked fine for about a year. Then the shift motor was thrown out of sync, which is apparently common. After breaking a tamper proof T20 head on the motor case i caved and bought a new motor instead of rebuilding. I got that put on and tested the 4x4, key turned, engine off. It engaged fine. When I test drove it 5 minutes later it wouldnt shift. I checked the module behind the drivers seat, and it was giving me a solid red light, so something went wrong with it. I should add that the blue and green sensor wires that are apart of the shift motor were kept on but i did not replace the single brown wire that seems to also be a sensor. It is currently cut, without a pin in the plug. Could that wire be the culprit?
