Transfer case fluid ?
PRanger
NorCal
What fluid do you put in ur TC? Don't know what's currently in mine but it's low and dirty need to drain and refill
Any help appreciated
982WDRanger
07/2013 OTOTM Winner
Chazy, NY
4.0L, Bored .030 over!
TC Fluid
You use ATF( Automatic Transmission Fluid). Just basic atf will be fine, but if you want to you could go as far as a synthetic. Royal Purple, and Mobile 1 make some. I currently use Royal Purple, which smells like cat piss but works great' shifts in and out no problem, no hissing or growling. In the end it is up to you and your wallet.
Ford makes an actual transfer case fluid for electric shift cases, it's just ATF with limited slip friction modifier in it. Regular ATF is fine though.
PRanger
NorCal
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
The manual calls for plain Mercon ATF. I have always used Mobil 1 ATF with no additives in all my trucks t-cases and it is fine.
The manual tells you to change it every 60k but it will look like tar by 30k. I change mine every 30k. It is easy to do yourself if you get a suction gun to fill it. Some Rangers have a round vibration damper covering up the drain plug, there are three bolts on the bracket to undo and it comes right off. The case is aluminum so don't over tighten the plugs or you will strip the threads. Just snug is fine.
If the lube in your 98 has never been changed (likely) and it has over 100k on it (likely) it may drain out like molasses on a winter day. Don't panic, but fill it, drive it 3000 miles or so, and change it again. Just to clean out the crud.
Late-model manual trannys call for Mercon ATF also.
L/S rears call for 80w-140, most of the synthetic axle lubes are 75w-140 which is fine. The front takes 75w-90 or 80w-90...know that on a 98-up the ONLY way to change the front diff lube without pulling the entire diff out of the truck is to take it to a quicky-lube (I go to Valvoline) where they drain it with a suction machine. Because there is about 3/8" clearance between the diff cover and the crossmember you will NOT get the diff cover off. Costs about $49, it's worth it.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
The rear diff actually uses 80w-90, except for FX4s with the Torsen LS, which uses 75w-140.
PRanger
NorCal
Thanks for the replies I really appreciate the input.
Ok I am draining cleaning and refilling my rear diff tomorrow. TC all done today.
Thanks again
PRanger
NorCal
Ok definitely don't recommend that crap castrol atf. Have a slight screech now in 4hi/lo from what I believe to be the TC. Funny I didn't have it when I was a quart short when I got the truck. changing to synthetic amsoil ATF tomorrow.
