- Dec 1, 2020
- 3
- Oceanside
- Ford ranger XL
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 2WD
I got a 1986 2.9l 5speed manual trans 2wd. The little ball on the bottom of the shifter lever fell off down into the trans. I could see it but could get it with the pliers so I moved the socket that the ball sits on down towards the seat. Fixed the bottom of the shifter so the little ball won’t fall off anymore. Now I can only shift into what I believe is 3rd and 4th gear have absolutely no side to side movement. Transmission was shifting just fine prior to the little plastic ball falling off. Did I screw something up when I moved the socket that it sits in? To wear it’s not aligned properly? Any help is appreciated. Also can anyone tell me what trans this is?
