towing my trail rig jeep with my new fx4????
westfx4
i cant find any posts about flat towing other vehicles behind a 4.0 ranger, only posts of having the ranger towed behind something else. what would you guys say the maximum weight and/or size dimensional vehicle can be flat towed behind an 09' auto 4.0 fx4 ranger? thanks a lot!
KELLY88
4
Lake Mary/Daytona Beach, FL
4.0, 4.0
Wouldn't the owners manual mention weight limitations for your truck for both hauling and towing?
westfx4
im sorry i didnt mention that because i dont have a trailer and i have manual hubs on the jeep, im going to flat tow the jeep. so, what are the limitations for flat towing vehicles for your ranger. another reason im asking is because i already lost my owners manual, got to go get another one.
Wicked_Sludge
43
Westport, WA
3-point-GO
fords towing guide is listed on their fleet website, HERE.
flat towing is still towing, the weight rating is the maximum you can tow, regardless of it being flat or trailered. their towing guide shows an auto ranger to be rated at a max GCWR of 9,500lbs with a maximum frontal surface area of 50 sq-ft. a manual is rated at 7,000lbs GCWR with the same frontal surface area.
rusty ol ranger
2.9 Mafia-Don
7,554
Michigan
177 CID
In the real world you could flat tow considerably more then you could trailer tow. There is no weight on the truck, which then presents a seperate set of problems such as sway and braking.
Ive seen people pull a Chevy 3500 dually on a towbar behind a Nissan Hardbody...what do you think would happen to that truck if you pull the 1ton on a trailer?
I personally drug my 77 LTD II down the road with a strap between it and my 08 Colorado, what do you think would happen to the colorado with a trailer and that car behind it?
later,
Dustin
Wicked_Sludge
43
Westport, WA
3-point-GO
braking is by far the largest limiting factor when towing. if you have 3,000lbs behind your truck, your braking will be impacted the same wether its on a (properly set-up) trailer or on the ground.
dont exceed the GCWR. doing so is illegal and ill-advised.
Jason
28
(formerly) 200
It should be fine but make sure you have good brakes. I pulled a 77 CJ5 with my Ranger when it still have shitty FMC brake parts and they faded to nothing at the first sign of a downgrade. I drive trucks for a living too so I know how to properly take a downgrade while towing. I can take a 45k pound load through the Rockies but I can't tow a 3800 pound jeep down a small hill with factory brake parts. Just upgrade the brakes and slow down BEFORE any hills. Then pick a safe speed for the hill and maintain 5 mph below it. Say 45 is the safe speed. Slow the truck to 40 mph then let it run back to 45. Repeat slowing the truck. Use a low gear if you can.
17,879
SW Iowa
later,
Dustin
With no trailer brakes or tongue weight it would be tougher to flat tow something long distance than on a trailer.
LEVE
The Palouse, WA State
I towed a SWB Caravan from St. Paul MN to River Falls WI (35 miles) in the dead of winter, once. It was the scariest tow I've ever done. The tail was wagging the dog. I would not even think of flat towing my CJ7 with my Ranger. I wouldn't hesitate using my PowerWagon.. but not the Ranger. It's not a power issue, it's a weight and wheelbase issue.
Will
514
Gnaw Bone, Indiana
Toyota
I've done both. Flat towing isn't safe, period. I'm floored by the suggestion that it is. You haven't friggin done it if you think it's safe.
I bought my B2 a long time ago, I forget when, in Virginia Beach. I had a '91 Ranger, swb 4x4. 4.0 and 5-speed. I took a towbar with me. AFter I bolted the B2 to the towbar it started to rain. I was going about 3mph to keep from sliding. Then, I went through the first intersection and suddenly traffic in from of me stopped. The B2 didn't get the word and it jackknifed me in the center of the intersection. I waited embarrassed for the light. Then I was on my way up the onramp and traffic again stopped. And I jacknifed again. Then I was on the interstat and had no other issues.
Here's the main problem flat towing--the steering box doesn't like to be forced the wrong way. The tires have a 15-1 advantage against them and they aren't interested in turning when you are.
But I'm sure it's absolutely safe besides all of the hazards I've pointed out.
Wicked_Sludge
43
Westport, WA
3-point-GO
ive flat towed on more than one occasion and i think it can be done safely. ive flat towed on icy highways in mid january a truck that weighted as much as mine that had poor front end alignment and i could still command authority over the towed vehicle. i even navigated a switch-back gravel driveway at the end of my journey with no troubles :dunno:
Will
514
Gnaw Bone, Indiana
Toyota
Well, you're a god.
I only suggest it for mortals in an emergency--or if the vehicle doing the towing is a lot heavier, particularly in the rear.
Jason
28
(formerly) 200
It's hard to say. I have never pushed the limits on a regular truck, but my rig is only 25k but it can safely pull 50k. Of course, the rear suspension is so stiff that it is almost undriveable bobtail so.......
jobar
Warner Robins, Georgia
3.0 liter
I personally would suggest not to flat tow. Just my opinion, but I never liked the idea of not having control of the brakes of the vehicle behind me. On the other hand, with a trailer that has trailer brakes, you have somewhat of control behind you and not dead weight. Not to say you cant have ever have problems with trailers, but I would feel safer. If it were me.
Wicked_Sludge
43
Westport, WA
3-point-GO
Well, you're a god.
dont take it personally will, i was just adding my thoughts. nobody here is right or wrong.
