Tow ball questions
rangertodd
I need a tow ball for my '99 Ranger. I'm looking for a regular ball to mount on the hole in the bumper. I'm not planning to tow anything heavier than a 14' aluminum boat so I'm sure the bumper will be fine. But where do I get a tow ball? And what size should I get? I can get a reese hitch ball (tow ball with lock washer and nut) at VIP or Walmart for around $10. Is this the same ball that Ford uses on the bumpers? I've never towed anything before so I have no idea what I need.:icon_confused: Thanks.
kunar
131
Toledo, Ohio
5.8l
thats fine, you just need to make sure its the right size. it may be stamped on the tongue of the trailer, i dont know for sure...
krugford
Iowa
The ball from Wal-Mart will be fine. Reese is a good name for hitches and accessories. As for the size, you'll have to look at the trailer you'll be towing and see what size of ball it takes. Common sizes are 1-7/8 and 2" for this size of trailer. Also take a quick look at the size of the hole in your bumper. They make different size shanks for the same size ball. You need to get the correct shank size. There is only a couple of different shank sizes so that should be easy as well. Good Luck!
-krug
rangertodd
-krug
I'll have to check out the hole size. It's a stock xlt bumper, so I'm sure it's a common size. Thanks.
rangertodd
Thanks. I don't have a trailer yet, but I'm looking at a couple different boats for sale, so I'll have to match the ball to whatever I buy.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
The hole in your bumper is going to need a ball with a 3/4" shank size.
Wicked_Sludge
43
Westport, WA
3-point-GO
since your truck didnt come with a towing package, you'll also need to add a trailer wiring harness for your trailers lights.
please dont cut and splice your factory harness. there are companies that sell kits that are 100% plug and play. they plug into your stock taillight wiring harness and also convert your 3 bulb lights into the 2 bulb system most small trailers use.
metalmacguyver
Yeah, I built that.
11
Plymouth MA home, Buzzards Bay MA
4.0, 7.3
and those are only about 30 dollars at walmart too. i got one and it worked great.
racsan
4,487
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
i had to replace mine last winter when i got a new box trailer, something inside the converter box went bad i only had 1 brake light, no tail lights or turn signals. but it sure beats the old days of probing wires, sticking your finger and soldering/taping the harnes together
________
volcano vaporizer
Guy
Nampa ID
5.8
Well that takes all the fun out of it
Wicked_Sludge
43
Westport, WA
3-point-GO
it does. but ive seen way to many hack jobs to not reccomend doing it the right way :icon_thumby:
dburton07
5
South Portland ME
3.Ugh
i got one too and its awesome. the only thing i had to do was change out the blinker switch because when the trailer was plugged in it flashed at a million mph
Wicked_Sludge
43
Westport, WA
3-point-GO
ahh yes, i forgot about the flasher, thanks for bringing that up. you'll need a heavy duty flasher to avoid hyper-active blinks.
racsan
4,487
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
i got the "loud" flasher, mine started to go bad and would slow to a stop if waiting on a light/traffic for long. couldnt hardly hear the old one with it being tucked up under the dash like it is.
________
Daihatsu Mira Gino specifications
