top end kits
Junglejoe
66
Columbia Missouri
6.0
Ported trick flow 170 heads..real good port work.. ported upper and lower intake, ported yhrottle body,mill the heads to 58cc, .035 headgasket.. a good cam and 30 lb injectors, 80 mm mas, headers.. youll be at 350 or very close to the tire.. fixing to dyno mine here very soon. Couple small things to do still
Junglejoe
66
Columbia Missouri
6.0
Head work is just a waste of money if you dont put a cam in and a better intake and throttle body and injectors. Get a dremel and some bits and port match the gaskets. It isn't that hard, There are plenty of videos online.
This will give you what you are looking for.
Gt40p heads port match the gaskets intake and exhaust sides (port and polish)
Gt40 intake or explorer intake same thing basically
Upper and lower plenum spacer
Sn95 fuel rail (flows better)
Trickflow valve spring kit
Ford performance B303 cam or equivalent.
new lifters
Trickflow Hardened pushrods factory length
Pedestal mount roller rockers 1.71 will work from proform
Tall valve covers
Double roller chain timing set cloyes will be fine
You can't just change one thing unfortunately and make the power you want and have reliability also. Price some of this stuff it wasn't to bad. my first motor was this setup it made about 300.
Tall valve covers wont fit the explorer intake without a spacer..and spacer costs hp
Ramcharger90
1,708
N/A na
306, Bcam,
Good with the bad..... its not a hundred horse.... that can be made up....
Again people need to do their own research..... figure out what works for them... that loss in hp is so insignificant over the gains in reducing drag in the valve train.
franklin2
1,769
Virginia
[QUOTE="Ramcharger90, post: 1784255, member: 103971"
[/QUOTE]
I am guessing that is why he is here asking questions. Part of his research/opinion gathering/fact finding.
gaz
671
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
2drexploder,
A quality flow benched port and polish job will cost approximately $800 + parts on iron heads; though valve guides are expected, you could get lucky on the rest of it being within spec.
There is a HUGE difference between this type of quality work and the "fabled" port match hack-job. If you are considering a cam to increase performance, definitely have the heads flow bench P/P as the machinist will be able to recommend a custom cam grind that is exactly correct for YOUR engine. Even if you aren't planning a cam upgrade having your heads ported and flow matched to your intakes with make a substantial improvement in performance efficiency. Ported heads matched to intakes will also benefit from good exhaust flow (headers and improved flow exhaust).
Junglejoe
66
Columbia Missouri
6.0
2drexploder,
What he just said.. period. Nothing more to add
franklin2
1,769
Virginia
2drexploder,
Add to the above machine work to convert to studs and guide plates so you can adjust your valve lash for your new cam. The price of new aluminum heads are more competitive after you add all that up. And they have better chambers, larger valves, etc.
Ramcharger90
1,708
N/A na
306, Bcam,
If you are looking to spend money go that route. If you want to save some money do what I did with the P heads. I am able to out run my 92 supercharged mustang. Ive done it before. I ran my friend when he owned the car. The Ranger runs like a champ.
306 short block with ARP bolts and wiesco forged pistons with H beam rods.
GT40P heads port matched
B cam
Trickflow lifters
Trickflow hardened pushrods
Proform pedestal mount 1.71 roller rockers
Trickflow intake
Bosch 24lb injectors
SN95 fuel rail
BBK 70mm throttle body
BBK 76mm mass air flow sensor
All of these parts will work with a exploder short block. It was the setup I used before. The thing that killed my first motor was the oil filter relocation hose blew out.
The pedestal mount roller rockers
And trickflow valve spring kit eliminate the valve lash adjustment which is what I wanted to do since its a DD for me also. You dont have to go back in and adjust anything after you run it for a while. The only thing you should do as in any engine build is make sure they are still torqued.
Also you can use that gt40 intake still and meet your power goal. Like I did before I put all new stuff on because the old explorer intakes like to crack at the thermostat housing and the ears on the upper plenum.
franklin2
1,769
Virginia
B cam
Trickflow lifters
Trickflow intake
SN95 fuel rail
I bet you did not have any problems because you used a Ford OEM camshaft. It's a crap shoot with the aftermarket camshafts.
gaz
671
Wa, Bremerton 98310
2drexploder,
A reasonable solution to any non adjustable valve train is a custom set of adjustable push rods from Smith Brother's. They charge about $11-ish each; 16 x $11, so approximately $180 plus shipping and your set.
Ramcharger90
1,708
N/A na
306, Bcam,
Ford performance B303 Cam. Its similar to a Trickflow stage 1
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
2drxploder
436
usa
ranger
347
lower
235 on 15s
thx yall, well weekend is here, and its raining, so no turning wrenches right now.
got a few more questions pertaining this swap ive been pondering
first is gas tank, what options are there to get a bigger tank? will the expo tank fit?
what mods are needed to make expo motor work in ranger pertained to fuel?
second egr, going manual trans so tuning will be required anyways, should i get rid of egr?
third is upgrade brakes for front? whats available?
99 ranger reg cab, 2.5 5spd coild sprung front 2wd
98 eddiebauer awd-donor
