facemaze
- Sep 7, 2020
- 8
- Austin
- Ford Ranger
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3l
- 2WD / 4WD
- 2WD
- My credo
- BirthTruckproblemsDeath
Just finally got my truck up and running off the blocks after a four month saga. I swapped rear main seal, clutch, flywheel, exhaust gasket and differential.
my issue is that,
when I put the clutch in revs spike close to 2000. When I engage the accelerated and release everything returns to normal. Until I get over 2000 rpm in gear, then I can release the accelerater and the truck will not slow on its own but will slowly increase speed. When coming to a stop with the stick in neutral, the truck will spike to 3000 before coming back to right above 1000 for a stationary idle.
I am taking my foot off the gas when I put in the clutch. I have no cruise control. I use a K&N air filter. When I swapped the diff, I used my newer abs sensor from my old diff on the new one.
the truck was running great with no issues after the work. The problem arose after spending 30 minutes on the freeway at 65mph
my issue is that,
