TK4 won't go into gear after TO bearing replacement
dwhile
Spartanburg, SC
2.8
I’ll compare the new cylinder pushrod length to the old one, but I believe it’s the correct cylinder. Idea about the pushrod sounds promising, I’ll see how cheap I can grab one from work. I started thinking the same about the power bleeder so I’ve been using a reverse bleed technique where the slave cyl is compressed repeatedly to force air up the line. Got a lot of air out and pedal feel is good, so may try longer rod. Thanks for the idea!
dwhile
Spartanburg, SC
2.8
Leftmost rod is the new slave cyl rod, middle is old cyl rod, and right is pushrod I just tried to replace the cyl rod with. The extra length on the pushrod did not help, still wouldn't go into gear. I have a little bit of stuff I need to do around the house then I'll go out and remove starter, have wife press clutch pedal, and see whats happening in there.
dwhile
Spartanburg, SC
2.8
Got some stills from a video I took of my wife pushing the clutch pedal. Looks good to me, anyone see otherwise?
8,370
"Looks like" it is pushing in far enough but hard to tell
But if you can't shift into any gear with engine running then it is not releasing clutch disc enough, simple as that
Clutch disc MUST slow down to 0 RPMs to put transmission into any gear when you are stopped, thats how it works
And why you CAN shift into any gear when engine is off, clutch disc is at 0 RPMs when engine is off
dwhile
Spartanburg, SC
2.8
Will bleed more, and I'm sure it'll work eventually.
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've had my best luck bleeding with a vacuum. I don't know if your system bleeder would be accessible. Anyway, here is a pic of my homemade vacuum bleeder. I hook up to engine vacuum.
8,370
Bleed it without slave pushrod in place, slave piston should have a stop that will prevent it from popping out.
My thinking is that the pressure plate resistance is not letting slave expand fully, so you are not getting full travel at the slave regardless of pushrod length, its being held in by the pressure
dwhile
Spartanburg, SC
2.8
Ron will try that tomorrow, makes sense.
1984ranger28
5
Davison, Michigan
2.8l
When I replaced the slave cylinder on my Ranger, I bleed the clutch using this kit here.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.amazon.com/ABN-One-Man-Brake-Bleeder/dp/B00SYQQ6KK&ved=2ahUKEwiD-vPY18bgAhWFyoMKHavKCOkQFjAIegQIBRAB&usg=AOvVaw2G6egm04BOhvR9BmuPAKTb&cshid=1550541116006
All you do is put the hose with the black nozzle and stick it in the hole in the clutch fluid reservoir, and put enough downwards pressure on the hose to seal it, and suck on the hose. Then just lift up on the hose and dump the fluid back in the reservoir. It took me about 15 minutes of repeating this to get it bleed, but it worked great.
dwhile
Spartanburg, SC
2.8
I saw a guy on Youtube do that, I'll have to grab one of those little black ends from work today and give it a shot.
Mike Tonon
Guest
Ah!... I see what happened here. That’s a throw out bearing. You’re supposed to throw those out.
dwhile
Spartanburg, SC
2.8
Tried applying suction through a nozzle to the master cylinder which did not result in any change. Removed the slave cyl pushrod and bled, still no change. After all the additional bleeding, pedal returns extremely slowly once fully pressed. Worse off than before. I think it may be a defective master cylinder. I'll take the cylinders back off the truck and bench bleed to see if I can produce any pressure in the system. If not, I'm considering trying to get a replacement master cyl.
8,370
Yes, at this point I would replace master
Denisefwd93
74
South East PA
Unless you have a bad connection with the push in click, line connector...
dwhile
Spartanburg, SC
2.8
If I can’t build any pressure in the system tomorrow I’ll bring it back to the parts store. I’ve only had it for a week, it should hold pressure.
