87broncoboy
- Jul 2, 2010
- 0
- Ford
- Engine Size
- 2.9l
Whats the largest tire i can run on an all stock 87 BII? it has a 2.9 and dana 28s i think.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I have the same B2. But, with 373 gears. I also have a 2" suspension lift. have been wanting to go with the 31s. But i am told and have been reading the forum that that isnt the best setup to run 31s. should at least have 456s to maintain the proper performance of the little b2.Whats the largest tire i can run on an all stock 87 BII? it has a 2.9 and dana 28s i think.
mine were rubbing on all 4s on driveways, small bumps, a passenger and making sharp turns on the 235 before i did the ear springs and the leveling springs. now it dosnt even come close. i think i gained the full 2 inches above stock all around.Check your springs out too. Most B2s have issues with spring sag just from age. You may get rub even with 30s if your leaf springs are wearing out.
i had 31's on 15x8's with 3.5"b/s with a 2" spacer and no rear lift, and it only scrubbed on full flex in the rear31"s will rub on it, stay with a 30" or 235/75 tires if its completly stock.
