Tires Tires Tires
87broncoboy
2.9l
Whats the largest tire i can run on an all stock 87 BII? it has a 2.9 and dana 28s i think.
Spowerback
Banned
--- Banned ---
California
FORD
v6 4.0L /
Your bronco probably has 3.55:1 or 4.10.1 gear ratio in the axles. stay at the 30" tire size :example---»»» 30/10,5/r15( 235/75 /15) maybe 31 not sure
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
31"s will rub on it, stay with a 30" or 235/75 tires if its completly stock.
Spowerback
Banned
--- Banned ---
California
FORD
v6 4.0L /
hey your reason RSH I'm wrong .I read the tread
b2rich
Lake Oswego, OR
whats an engine?
I have the same B2. But, with 373 gears. I also have a 2" suspension lift. have been wanting to go with the 31s. But i am told and have been reading the forum that that isnt the best setup to run 31s. should at least have 456s to maintain the proper performance of the little b2.
currently i have 235s on it and i will probably keep them on that way for awhile.
Original_Ranger84
20
2.8L, 3.0L
Welll you need 4.10's with 31's and 4.56's with 33's. But I'm running 31's on both my 84 (2.8L) and 99 (3.0L) with a little drop in performance but not really noticable with the 3.73's.
But I would say stick with 235/75R15's any bigger then that and you'll be rubbing more then likely
87broncoboy
2.9l
Ok thanks everybody. Im new to the world of smaller 4x4s.
87broncoboy
2.9l
Haha well regardless, thanks.
3,614
Check your springs out too. Most B2s have issues with spring sag just from age. You may get rub even with 30s if your leaf springs are wearing out.
87broncoboy
2.9l
ok great, i wouldnt have even thought about that.
b2rich
Lake Oswego, OR
whats an engine?
mine were rubbing on all 4s on driveways, small bumps, a passenger and making sharp turns on the 235 before i did the ear springs and the leveling springs. now it dosnt even come close. i think i gained the full 2 inches above stock all around.
87broncoboy
2.9l
Thats awsome thanks for the info.
The_Dealer
10
Macon, GA
Duh!
i had 31's on 15x8's with 3.5"b/s with a 2" spacer and no rear lift, and it only scrubbed on full flex in the rear
Ranger Kip
10
Wellsboro, PA
Ford Fleet
3.slow
Confused and Intolerant
any size you want, all a matter of how bad you want them to fit....
