Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Get shocks for the amount of lift you want, these questions have been answered many times in this thread. 2in coil spacers for the front, 2 inch lift shackles for the back. Body lift if you want more. Get shocks for the amount of suspension lift you add on. Any shock website or shop will have applications clearly listed for your vehicle with the amount of lift you have.Ok, so how much of a shackle lift should I go for with the coil spacers up front? I can buy up to 2.5" long shackles. I know my leaf springs are sagging, so would longer shackles compensate for that?
How much longer shocks will I need in the rear to accomodate the 2" suspension lift?
I agree with this guy and if your rear sags 2 inches then the rear should o ly be like 1-2 inches higher.This is what I would do, get the 60.00 axle flip kit, that will give you about 4" lift in back, then do the washer spacer lift on the front from the tech page, that will give you 2" in front, and then just go with the 32's and be done, that is the cheapest way to go.
you might end up with a little forward rake, but it would look alot nicer then dragging your tail.
Robert
