RustyDusty
- May 13, 2021
- 14
- California
- Ford Ranger
Hey my 1987 ford ranger with the 2.9 has a few issues that I've been trying to track down. It likes to die right after I start it. Idle is a bit sporadic, goes up and down and up and down, sort of like a pendulum. It also likes to die when I take it out of park and put it into gear whether its Drive or Reverse. After I start it up again it will usually go into gear without dying, it just likes to die the first time around. I checked the codes and got one for the throttle position sensor voltage out of range. I tested the sensor and sure enough it was 1.34v with closed throttle and 4.75v at wide open throttle. I searched for a while for a Motorcraft brand replacement but I couldn't for the life of me find one for my year/make so I settled for a Walker brand. When it arrived I threw it in and tested it with the multimeter and I got the same exact numbers. This has me a bit stumped. Did I actually just have two sensors with the same incorrect voltage or is there something else that might be happening here? Bad ground? I decided to take a soldering iron to the little plastic wheel on the old TPS to melt the fins back a bit to attempt to lower the voltage at closed throttle and was able to get the reading down to 0.88v at closed throttle. I'll take it for a test drive later to see if it has any effect. I also used a vacuum gauge to see what that would tell me and the needle was moving around a lot, would go down to the area that signifies late ignition timing. I guess the next step should be busting out the timing light?
