DirtBikeDevil33
- Feb 20, 2019
- Reaction score
- 0
- Location
- loveland co
1996
- Make / Model
Mazda
Jeep
- Manual
Hello everyone I have a 94 B4000 that I bout about a year ago to take to the mountain and beat the crap out of. witch I did indeed to haha. anyway my first question is it to run the v6 with open headers because due to doing a new clutch system ( slave and master) I cut the y pipe out right after each o2 sensor. with isn't much considering I was still running it open headers before that. anyway. the truck starts then you can drive it but when you first start driving it has nooo power and if you go over 1/2 throttle it almost bogs out hbut more so just kinda stays at the same rpm while struggling. after it warms up it does a little better. the ther hing is it sounds like its running on about half the motor at time as you can her a reall loud hollow popping noise almoist at times when yuour idleing. and sugjetions would be nice but im sure ill have to end up pulling tho motor now to do a head job or much more. ive proudly beat the ****ing piss outta this origanlay 800$ truck. now I have a 500$ remaned junkyard rear end. ass well as 200$ for the pre bled master and the slave. I also replaced the front axle shafts and wheel bearing on the front due to completely snapping the u joint off one
