T5 crossmember
Junglejoe
66
Columbia Missouri
6.0
Yes, stock t5 mount fits perfect. To be specific, mine is from a foxbody . Im not sure if the sn95 is different
Ramcharger90
1,708
N/A na
306, Bcam,
Sn95 is suppose to have a longer input shaft.
svtcards
137
Lyman maine
302
3'' front 4''back
Good to know.i was contemplating getting that crossmember for mine.now maybe I might.thanx for info
svtcards
137
Lyman maine
302
3'' front 4''back
svtcards
137
Lyman maine
302
3'' front 4''back
I wonder if frames are similar on yours to my 1st gen
Ramcharger90
1,708
N/A na
306, Bcam,
Supposedly the frames are about 2 inches wider on 96 and up trucks.
2drxploder
436
usa
ranger
347
lower
235 on 15s
Yall have to get a different driveshaft for t5?
svtcards
137
Lyman maine
302
3'' front 4''back
Is it to long or to short?
svtcards
137
Lyman maine
302
3'' front 4''back
I have a sn95 as parts car that has t5 In it already.hoping that your fit right in.if not best case scenario it's to long and I need it shortened.fingas crossed.
svtcards
137
Lyman maine
302
3'' front 4''back
Ricks rangers crossmember bolted to a t5
When u have it mounted up to crossmember does your shifter mount seem to lean to the driverside or does it sit perfectly flat and even with your floor?
svtcards
137
Lyman maine
302
3'' front 4''back
Does your shifter seem to lean towards the driverside or does it sit level with your floor board?
Junglejoe
66
Columbia Missouri
6.0
The foxbody t5 has a lean to it, even in a mustang chassis if thats what you mean
svtcards
137
Lyman maine
302
3'' front 4''back
That's exactly what I mean.thank u for the quick response
