Switch from Torsen to Locker
timmyflew
6
North Carolina
Ranger FX4
Minor T Bar Crank, Stock Rear
32x11.5x15
So I have a Torsen in the rear from the factory. I want to put in a lunchbox locker. Aussie locker's website says it only works on open diffs. Does anyone know what I would have to do to install an Aussie locker? Will I have to completely remove the carrier and get an open diff from a junkyard to install the Aussie in?
sheep herder
1,024
sheep pen
If it ain't broke, break it.
You will have to replace the carrier.
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
Yes, you would have to remove the factory torsen, a factory open carrier from a junkyard would work.
timmyflew
6
North Carolina
Ranger FX4
32x11.5x15
Thanks guys. Wanted to make sure I was going in the right direction.
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
So, something to double check. If you have a later model ranger with the factory torsen, you may have 31 spline axels in the back. A carrier for a 28 spline wouldn't work.
I'm sure new carriers are available that would work, or maybe a used open carrier from an explorer.
Definitely need to verify which rear end you have.
timmyflew
6
North Carolina
Ranger FX4
32x11.5x15
I'm sure I have a 31 spline from the information I got of this site. I plan on checking the pick-n-pull to see if I can find a carrier. I wheeled all of Uwharrie except for the two ledges on Daniel and haven't even lifted a tire so Will probably do more wheeling first before I decide on pulling the Torsen.
fastpakr
2,841
Roanoke, VA
I thought all the Rangers with factory Torsen lockers were 31 spline? Am I losing my mind here?
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
I'm pretty sure all of the factory rears with torsens are 31 spline.
The junked open carrier also needs to be from a 31 spline. I think!
fastpakr
2,841
Roanoke, VA
You're absolutely right. I misread your first post. Definitely worth paying attention to when grabbing a carrier.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Kinda sorta not really... L/S units (dunno if they were all torsen) were available for the 7.5, as well as both the 28 & 31 spline 8.8 at least at some point and vice versa with open carrier.
Finding a 28 spline doesn't mean it won't have a L/S and finding a 31 spline doesn't mean it will. From my understanding ALL the fx4 lvl 2's had 31 spline and torsen units so that's probably where that info is coming from.
fastpakr
2,841
Roanoke, VA
Agreed on all points. But if it's a Torsen locker specifically (mechanical limited slip) and not just a generic clutch pack type limited slip, it should definitely be a 31 spline unit.
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
Make sure to bring your measurin' calipers and counting fingers!
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
In any case your much better off trying to find an open 31 spline carrier in a panther car or mustang than in a ranger. Pretty much all the Panthers had 31 spline open carriers, rangers not so much.
timmyflew
6
North Carolina
Ranger FX4
32x11.5x15
Is that because it would be easier to find?
fastpakr
2,841
Roanoke, VA
What's a Panther car?
