Switch Frames or SAS
cjgibson
Indiana
4.0L V6
I would like some opinions on weather it would be best to put a 1994 ranger extended cab on a full frame or do an SAS? What frame would work and any other info you can think of would help.
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
That would really depend on what you plan on doing. Both are going to be work, and will achieve different things. What are your intentions for the rig?
cjgibson
Indiana
4.0L V6
All i really want is a super tall ranger. i want to be able to fit 44 inch tires. the truck is under the knife right now. gonna be a show truck. it will never see mud or trails or snow or sand. i want it to look good not like some guys you see with a super tall truck and big tires but their drive shaft is the size of a drum stick. Want to have a wider stance with at least ten to twelve inches of lift. Cutting the fenders is not an option.
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
In that case, do a drop frame ala monster truck with a front and rear four link and run rockwells. The only thing a fullsize chassis is going to get you for your purpose is more weight, and more work doing a body swap.
cjgibson
Indiana
4.0L V6
looking to not spend alot of money. i think a four link setup is a little out of my league. unless someone on here would be willing to help me out.
wahlstrom1
J-man HD Mech
21
Edmonton Alberta
I could build a 4 link cheaper then a pair of 44" tires and rims..... you have priced them out right? Around $500+ per tire.....and your gonna need the axle to run them, even on the street your asking for issues running less then 1 tons.
Original_Ranger84
20
2.8L, 3.0L
Yeah I would stop right here if money is an issue. Your looking at atleast 5,000 just in the SAS or whatever and Rims and tires. Depending on the rims and tires that is cause you could probably spend easily over 1000 dollars per rim/tire combo. Not to mention all the restoration thats more then likely gonna need done.
Is this going to be street legal too? If so I would also look into a motor swap or finding axles that you can get a 7.--:1 ratio for so that your motor can turn them easily on the streets.
crawlin91
60
Crawlorado
2.9, 4.0
:badidea: Have you ever seen the big gay truck thead on pirate, read through it and then maybe reconsider.
$2k on tires just to show em off....really?:icon_confused:
cjgibson
Indiana
4.0L V6
any one close to me who knows how to build a four link set up? I plan on putting in a built 302 as soon as i get the time this winter. The truck in your picture is a little over kill as far as the height goes. Any body got any suggestions on what frame i should use if I went that route?
cjgibson
Indiana
4.0L V6
Swapping Frames!!
I need some advise on doing a frame swap. I have a gen. 3 ranger extended cab short box. What would be the best frame to swap my body onto. I heard that a 78/79 bronco frame is close to the same and all you had to do was put the body mounts on the inside of the frame. Dunno much about it just need some good advice.
stegomon
20
auburn/minot maine
fords and only
what is wrong with your frame?
JohnnyU
"Outlaw"
8
Chillicothe, Illinois
Chevrolet
Ls2
Where are you? Indiana is a big state.
85_Ranger4x4
17,929
SW Iowa
If you can find someone junking out an old combine, you can get big aggressive tires pretty cheap.
I picked up a pair of 14.9-26 tires with good tread mounted on good steel rims for $50.
The rims are not really classy, but for a true enthusiest tires don't come much meaner. Probably not the greatest tire for the street, but then neither is a truck with 12" of lift.
cjgibson
Indiana
4.0L V6
nothing i just want a full size frame under my truck in order to make it taller and get rid of the ttb
