Dirmaid
- Feb 22, 2011
- Reaction score
- 3
- Location
- Louisiana
- Make / Model
- Ford
- Engine Size
- 4.0 SOHC
- Automatic
Ok guys, I figured I could get this done on my own, but I'm tired of replacing ABS sensors. I've got a DJM 2/3 kit on my 01 Ranger (Auto RWD with 4.0), rear shackle is on the inner hole and the front bump stops are pancakes so I'm sitting around 3/4. I bolted on a BII rear sway bar and at first everything was fine, but it ended up rubbing on the pumpkin and making my ride absolutely terrible. I re-positioned it and it started unplugging the rear ABS sensor on a good sized bump. I moved it again which has prompted it to start actually breaking the sensor. How are you guys clocking the sway bar mounts on the axle? I've been doing my adjustments on the ground at ride height for reference (yes I'm very skinny so I do actually manage to crawl under the truck)
