Swap?
1jasonmoody1
9
Soldotna Alaska
Can you put a 90TM 1994 4.0 in place of a 95TM 96 4.0....not sure which vehicle the 94 engine came from but it will be going into a Ford ranger
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
Youre going from an OBD II motor/electronics to an EECIV engine/electronics.
Itll bolt in and hook up mechanically, but the ECMs are different and probably wiring to.
2011Supercab
467
Washington
Toyota Tacoma
I think you use the 94 long block and put the 96 intake manifolds, injectors, throttle body and all that stuff on to the 94 it works.
1jasonmoody1
9
Soldotna Alaska
Thank you for your input I appreciate your replying I'm going to start checking into that switch over the top half
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Wasn't 95 when they changed heads/pistons to make the O2 sensors work better or something? I'm sure it'll run. Just wondering if that will cause any quirks?
