Stuck in Eureka, CA!
MojoWorkin
6
Campbell CA
Supercab 4x XLT
Differential is giving me the death rattle after losing an axle seal and I'm in a pickle.
Going to fix it sell it or tow it. Dont know yet. I put ads in Craigslist for a shade tree mechanic or to sell it. (Humboldt Craigslist)
Just putting it out into the world.
49583
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Death rattle?
What's wrong with it? Does it still have fluid?
MojoWorkin
6
Campbell CA
Supercab 4x XLT
When the leak seemed pretty bad, and I was concerned that the differential was getting too low, I filled it. The plug was covered in silver goo and had some nasty metal chunks. I got another 120 miles before I started feeling like I was driving with the e-brake on.
What's funny is if I let it cool, the drag goes away. But the sound doesn't . Groaning.
8,370
Look on your drivers door label for AXLE Code
Seen here: https://www.therangerstation.com/tech_library/axle_codes.shtml
Since its a 4x4 you HAVE TO match the ratio
When you have the ratio you can go here: car-part.com
select calif
axle assembly rear w/housing
8.8"
9" brake drum here: https://www.ranger-forums.com/attachments/drivetrain-tech-37/50970-rear-brake-drum-size-9651-4.jpg?dateline=1346709884
10" here: https://www.ranger-forums.com/attachments/drivetrain-tech-37/50971-rear-brake-drum-size-18-9498.jpg?dateline=1346709884
Obvious difference, 9" has fins, 10" is smooth, so have a look at what you have now
You can use a 1993 to 2009 Ranger or Mazda B-series rear axle, its just wrench work, plug and play
I would plan on buying 4 new u-bolts but since its been lifted the ones in there now might be new enough to re-use
Locking differentials are better but cost more, you can use either
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Just another 240 miles and you could have been singing this...
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Being trapped in California is one of my worst nightmares...
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
But John Fogerty makes it sound so delightfully melancholy...
MikeG
752
central Texas
B4000
2"
235/75r15
He was probably stoned out his gourd at the time.....
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Still hands-down best CCR tune ever put out there.
OP: you ate a bearing, not sure which. Overall, an 8.8 is not a difficult diff to rebuild, just seems more complicated than it actually is.
The shame of it is that a complete diff is typically under $150. May be worth looking into a uhaul to get er home.
Jim Oaks
Administrator
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
You can likely find a used Ranger axle cheaper than paying someone to fix that one.
I've purposely avoided California. I'd never be stuck there. Even if I had to cross the desert on a horse with no name.
MojoWorkin
6
Campbell CA
Supercab 4x XLT
The axle code is R6
I had an idea though. In order to get home, am I nuts in considering dropping the driveline and putting it in four-wheel drive effectively making it front-wheel drive? I just got to get home.
8,370
You can but it wouldn't help, rear axle still need to turn, powered or unpowered
You could get a couple of the tow dollies for the rear wheels and do it that way, although you would probably get pulled over, lol
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
The only way driving in front wheel drive would help any is if you locked up the back wheels and dragged them on skis...
Junk Collector
Truck of Month
4,802
Rapid City SD
If you're gonna do front wheel drive... pull the rear axle apart, remove the ring gear and clean it out really well and reassemble. That way just the axle shafts spin freely.
I got my '88 from a towing company. They said that the previous owner had been driving it around in front wheel drive for YEARS. The rear driveshaft broke and he just removed it and kept on going. I believe it, the front end was trashed.
