Stubborn crankshaft pulley
Otto57
7
Michigan
Does anyone know a good way to remove a crankshaft pulley from an early 2.3 that has no holes other than the center hole. The bolt has been removed but it is very stubborn. I am used to using a puller that attaches to threaded holes in the pulley. I am not going to use the pulley because i wanted to use a serpentine pulley so, can i heat the pulley? Any help would be greatly appreciated. Thanks
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Heat, penetrating oil, since you’re not re-using the pulley, you could throw a 3-jaw puller on it.
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That's not a crank pulley I've ever seen...
But I agree with Eric...
Otto57
7
Michigan
Ok i will give it a try, thanks
scotts90ranger
4,367
Dayton Oregon
2.3 Turbo
yeah, and while you have pressure on it, tap it around the circumference with a hammer. You'll probably have to put the crank bolt in and push on that but you probably already figured that out.
Rusty Bouquet
36
Portland Oregun
Ford Ranger xl
In the antique bus scene, we use heat and paraffin wax. I thought it was a dumb idea the first time I heard it, now I have a little chunk of wax on stand by, at all times.
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Drill and tap a couple holes. If there isn't enough meat to tap then use bolts and nuts with your puller.
