stiffening up the rear end
TheDanger2801
Orono, ME/Yardley, PA
I would like to make my rear end a little tighter so that when i pull trailers my rear doesn't drop. Anyone know good ways to do this with out having my rear end get a 3 inch lift. maybe add-a-leafs or explorer leafs? will those give me lift?
mhughes165
9
302
they will give u lift, but if u plan on doing ALOT of towing, lookin into rear airbag systems that go inbetween you spring mounts and the frame, i installed those on my old f-250 tow rig and eliminated all squat issues without sacrificing flexibility(just inflate when u will be towing)
but if ur going to be just pulling a trailer here and there a add a leaf will get the job done fine, and u might also look into airshocks for the back for moderate towing
rngrdngr
SO CAL
FORD
depending on how often u need the heavier suspension i would go with a pair of Monroe SENSA-TRAC LOAD ADJUSTING SHOCK ABSORBER from rockauto.com there about 100 bucks and they wont add lift to the rear of ur truck,its not expensive like air bags , provides up to 1200 lbs of assistance.keep ur original rear shocks so if u decide to go on a long drive with no extra weight like a quad it takes 10 mins to pull off the Monroe shocks and put the originals on for a comfortable ride.if ur interested i got a good pair i will sell for 50 bucks to save u money.just pm me.
swtjames23
Eureka, CA
4.0L V6
+1 on the airbags. Checkem out here:
http://www.suspensionconnection.com/cgi-bin/suscon/2172F.html
P.S.--> I know it says it won't fit the SC 6' bed but i put em on my truck which is a SC 6' bed :icon_confused: not sure what thats all about. All you need is a drill, 1/2" bit (i think), some hand tools and a couple hours. I put the fill valves on the rear bumper on either side of the license plate. Looks real clean.
TheDanger2801
do the shocks basically do the same thing as say an add a leaf? just minus the lift?
88mudder
waterford michigan
heavy duty spring packs are nice for towing trailers, but once u tow a big trailer it wont do much
