Sticky Clutch Pedal Fix
8,370
Pushrod doesn't come off the Master
There is a one-way clip that holds it on, so it can be attached to the master but can't be pulled off the master
It can be pulled off but clip usually breaks
Yes, unbolt pushrod from pedal, then unbolt master from firewall and then twist master and pull it out of the firewall, it has a twist lock
backporch
9
NJ
Ranger Off Road
245 75R16
thanks. realize I need to remove the plastic fender liner. Another project for another day.
backporch
9
NJ
Ranger Off Road
245 75R16
Any tips for getting the assembly past the brake master cylinder's pushrod? Not much room to pull the brake master cylinder and booster foward and the spring in the master cylinder is just tough enough to make it difficult to press in the rod.
