Junk Collector
Truck of Month
- Mar 4, 2008
- 4,802
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
I had this exact problem. The escort bendix (10 tooth I believe) solved my problem permanently.
same problem, whats new. 97% sure both of our tailgates dont open either
what were the steps you took? is it just a matter of swapping out starters? or is it more work to that? broke 18 year old im on a budget
What part number are you guys using for your 10 tooth bendix? I looked into this quite a while ago and found several conflicting part numbers, it would be nice to have accurate information in the tech library.Mad Max had another thread going and he swapped in the 10 tooth escort bendix and it solved his issue also. You have to get the correct bendix (the gear assembly on the end of the starter) and then you have to take your starter apart and swap the gear assemblies out.
Do a search on "10 tooth bendix" and see what comes up.
