square tube driveline help
ltuck808
portland oregon
2.9
So I have a b2 sas with a jeep Dana 30 with the auto hubs. I know square tube drivelinws work on toyotas even driving 60 on the high way as long as the hubs are unlocked so its not so noisy. But im curious if I will have problems cuz the auto hubs? sorry to bring jeep stuff on the forum but its still a Ford truck! Please help I dont wanna get it done and have to take it right back off
martin
23
St Bruno, Quebec
1991
I've never seen a d30 with auto hubs.
ltuck808
portland oregon
2.9
Well they aren't manual hubs. What do you call them? That doesn't have anything to do with my question anyhow
scooter
October OTOTM Winner
49
N.W. Oklahoma
5.0L
Look (find) my build thread, i am running square tube driveshafts. Mine are HEAVY DUTY!!! 2 X 2 1/4 wall and 1-1/2 X 1-1/2 1/4 wall. you have to grind a slot in your inner tube for the seam on the inside of your outter tube...
There ok, but for a rig thats gonna go over 35-40mph, just make em round like there supposed to be. IMHO.
Todd S.
legoms013
09/2013 OTOTM
26
CA
4.0L V6
Its not a noise concern, it is a vibration concern. If you have hubs however to disconnect the tires from driving the front drivetrain while in 2wd, go for it.
Rolled Ranger
Puyallup, WA
'91
This has a lot to do with your question! Your Dana 30 probably does not have disconnecting hubs. That mean the front shaft is always spinning. This is a very good reason for a normal driver shaft.
Sent from my SAMSUNG-SGH-I777 using Tapatalk
4.0B2
151
Walls, MS
4.0 v6
some d30's have vacuum disconnects and junk, that work half the time...
with a d30 and no manual lockouts.... don't do square unbalanced shafts.
make a real shaft. there are plenty of d30 swaps on here, i'm sure you can find the info you need to figure out what shaft to use.
Sasquatch_Ryda
Forum Staff - Retired
92
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Stock shaft won't work for you? They do for most.
ltuck808
portland oregon
2.9
It's not non vaccum I wouldn't buy that garbage and the stock shaft slips out of the case and ive been looking for months for the rare case and cannot find one. I'm already sas'd but my driveline falls out all the time and I'm about to do my Duals so then I'm really gonna need something.
projectnitemare
8
Osceola Mills, Pa
396W
Get a new tube put in your existing driveshaft, around $100 in most cases.
Matt
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
He could always have the Jeep CJ7 Dana 30 with lockouts... :dunno:
Either way, DEFINITELY go round tubing for the driveshafts. It's inexpensive to have them lengthened and balanced at one of your local shops
