Spring level or Spacers?
ridgerunner
Tioga County, PA
Just want your thoughts. Should I get springs to level the front or spacers/washers (BTW looked at washers and they are nearly $70!). My 94 only has 68,000 gentle miles on it (no winters). Should I get the springs or go with washers/leveling spacers??? I want the best ride possible without any headaches when I align it.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
If your existing springs are in good shape, spacers should be fine.
ridgerunner
Tioga County, PA
Mkay, thought washers would be around 20-30 bucks but can't find them anywhere around here and on the net they are close to $70 bills. For not a lot more I could get new springs. Thought too that by adding a spacer would stiffen up the stock springs and give me a bad ride. Any thoughts?
ridgerunner
Tioga County, PA
Yeah I know some of U will think "look at the tech. section" but I have extensively...I want to hear honest hardcore responses from those who have done this. Any input would help sway me one way or the other. Fire away...
Jim Henderson
West Central Alberta , Canada
4L V6
I am running a 94 and went to F-150 springs and 1 1/2 of washers to give me the lift I was looking for. This is before the front end alignment . :yahoo:
Surrey
10
Vancouver, Canada
2.9
Those f150 coils can't be very soft though...
You can make your own washer spacer by buying some large-enough washers and putting them under the spring. A quick bead of weld is a good idea to hold 'em all together. Mine cost like $6 to make.
Poly spacers are known to break down after a while, especially if you abuse it.
swynx
9
lewiston idaho
Mazda
I received mine today. They look to be of quality.
