sohc oil pan swap
downer
4
97 4.0 OHV 4x4
questions on how the sohc oil pan is bolted on.
do i need to use the sohc main bearing bolts? i'm not familiar with the sohc. is the upper pan actually bolted to the main bearing caps somehow? i'm looking at the 8 hex head inserts in the upper pan and this diagram and scratchin my head. 3:icon_confused:
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
The upper oil pan on a 4.0SOHC engine is also a main\ bearing stud girdle
downer
4
97 4.0 OHV 4x4
fyi, i did need to use the sohc main bolts
