- Jun 2, 2012
- 8,374
- canada
- Ford
Yes, if one front hub wasn't locked there would be no drive wheel in the front, and if surface was slippery then no steering so you would slide in a straight line assuming rear wheels were still pushing in 4lowIf either front tire is spinning (whole lot easier to spin an axle without a tire attached to it in an unlocked hub than a single tire breaking traction), both hubs are working, and to slide sideways means both front tires are spinning
a WHOLE LOT simpler solution is just to air down the tires a little, if you're running street pressure like 30psi, even dropping down to 20psi will be a game changer at least on the front tires and as long as you aren't driving for really long distances shouldn't hinder tire wear all that much
Yes, letting out some air gives a better footprint for traction
