slight knock and hard start
joshuakaesekamp
California
ford ranger
hello i have a 2001 2wd regular cab with the 3.0 v6 that i just bought and it has a slight knock sometimes it sorta changes to a tick it only knocks at under 1500rpm or when under load. it also has a hard start i have to crank it alittle longer than normal but there are no power losses and no check engine light. i assume the hard start is fuel pump but not sure. i replaced all spark plugs and coil and the fuel filter looks to be new. the cylinders closest to the fire wall were both melted on the tips of them. i have checked valves and the sound is not coming from them. and it starts like normal if you start it right after you turn it off. could it possibly be a fuel knock of some sort. i have also put fuel injectors in that i know for sure work so i dont think it can be anything with thoes. any help would be much appreciated thanks in advance
franklin2
1,758
Virginia
Bronco II
You need to put a real oil pressure gauge on it. You can get a tester gauge or just buy a cheap oil pressure gauge in the store. If the pressure is low, and the needle bounces with the knock, you have serious engine problems. If the pressure is good and steady, then it's something more minor.
joshuakaesekamp
California
ford ranger
would you know where i would connect the gage to like where on the engine. would i just put it where the factory oil pressure gage or is there another spot
franklin2
1,758
Virginia
Bronco II
Yes. Take the factory sending unit out and put the mechanical gauge with the tubing in it's place. They work best for troubleshooting.
joshuakaesekamp
California
ford ranger
so i ended up getting a motor for really cheap and i ended up just swaping motors witch fixed the issue but thanks for the help
