Side-to-Side Movement under Hard Braking
Bgunner
1,088
Western Mass.
Ford/Ranger XLT
225/70/R15
Normally if it pulls to the right it's the left not working properly. Or vise a versa, if it pulls to the left the right is not working properly.
idahorally
4
Florida
Ranger 4.0L 2WD
Yes sorry, it is the rear DRIVER, not holding pressure.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,506
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Air won't just jump into the system... unless there is a leak.
Personally I wouldn't waste any more time bleeding... it's time to pull some wheels/drums off and give the brake system a good look.
idahorally
4
Florida
Ranger 4.0L 2WD
@Uncle Gump yessir, that’s my next plan of action. Going to order a new set of everything for the rears and then just tear them down and replace what needs replaced.
MikeG
752
central Texas
B4000
2"
235/75r15
Yeah, sounds like you could have a wheel cylinder leaking into one of the drums. Brake fluid between the shoes and drum really screws with the coefficient of friction.....
idahorally
4
Florida
Ranger 4.0L 2WD
Wellp everything arrived today.. New drums, shoes, hardware/springs, adjuster mechanisms, wheel cylinders.. Ended up only being $100 shipped for the lot. I'm off Monday, so I'll tackle it then.
Uncle Gump
Token Old Guy
13,506
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The plot thickens... another reason I'm not a fan of wheel spacers.
I would take a propane torch and try a bit of heat. Not cherry red hot... jost hot. Probably had some loctite added for good measure.
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
Well started the swap and haven’t made it far. I can’t these to break free.. impact, breaker bar, nothing.
Sounds like you need more PB Blaster and a bigger impact/longer breaker bar. Can try to use your jack to push up on the breaker bar.
idahorally
4
Florida
Ranger 4.0L 2WD
Headed to harbor freight to get a torch and some pb blaster as we speak.
Roert42
5,000
Kintersville, PA
Ranger XLT
4.0 SOHC
Home Depot Sells it by the gallon. $20 gets you a gallon of PB Blaster and a spray bottle.
idahorally
4
Florida
Ranger 4.0L 2WD
PB blaster and the jack bar as an extension got it done.. didn’t have to bust out the torch.
This being my first time redoing drum brakes, I can now say it’s a royal pain in the ass. Anyway got it all done. Wheel cylinders were definitely the issue, and all of the springs/adjusters were toast too.
pedal is firm again, e brake stops on the 3rd click, no more pulling to the right braking and I have a lot more stopping power. ABS light does still come on if I really mash it down though.
Thanks for the help guys.
Uncle Gump
Token Old Guy
13,506
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would just make sure you re-torque all the wheel fasteners after a hundred miles or so...
idahorally
4
Florida
Ranger 4.0L 2WD
Yessir, I’m used to doing that. I’ll hit the spacer lugs again too.
idahorally
4
Florida
Ranger 4.0L 2WD
So a little update, I ended up replacing the master cylinder too and that really had an improvement on the braking as well.
Fast forward to this weekend, I was on a pretty rutted south Florida highway and caught one pretty good, immediately lost about 70% braking power. Upon inspection today, I found that one of the brand new "Carlson Pro" drum adjuster assemblies sheared clean in half.
