idahorally
- Jan 1, 2021
- 4
- Florida
- Ranger 4.0L 2WD
I've got a 94 4.0 2WD that has some pretty terrible braking power. Pads and rotors are in good shape, however under hard braking the truck will dance pretty aggressively from side to side. When I first bought the pickup the previous owner had a jumper wire in the Brake Fluid Reservoir Sensor to prevent the ABS light from staying on, I went ahead and replaced the sensor. The ABS light stays off, unless you guessed it, I mash the brake pedal all the way to the floor. Whether or not I am parked or driving, this is the case.
I am considering potentially just replacing the entire front setup, calipers and all. Any guidance on where else to potentially look for a culprit?
